I've got most of the interior gutted out and I'm working through some of the wiring now. I'm still getting used to the way the GCR is written as it's a little different than the Solo rule book. With regards to the wiring I have a few questions.
9.3.32 states having two brake lights which is easy enough. It goes on to say, but it doesn't require them to work.Turn signals, front parking lights, backup lamps,
and side marker lights may be taped or painted
9.1.3 10a states.Wiring specific to any component permitted to be removed,
or disabled, may be removed
9.1.3 9c....Switches to activate the ignition, the lights, the windshield
wipers, the starter and other accessories located within the
passenger compartment may be replaced and their location
changed
I'm trying really hard not to read into this too hard. I can't see an allowance for removing wiring going to "auxiliary" lights because there is no allowance to "remove" the switches for those lights...only replace and change location.
Am I missing something here. I don't want to spend a lot of time sorting through wiring and end up removing something I'm not allowed to.
I also have a rear window defroster circuit that isn't specifically addressed although it may be in an UD/BD.
