To refresh everyone....
What we have is a case of multiple (and findable) sources that list 110 and a microfiche (and unfindable) source that lists 120, correct?
- Is the microfiche for an unmodified US car as sold in the US?
- What is the source of the microfiche (factory publication? trade magazine?)
- What is the citation for the microfiche so that those with an axe to grind can go to a research library and do some digging?
- Was the 120 BHP, SAE Gross, SAE Net or SAE certified?
It's because no consistent method has been used to classify the cars. Newer classifications have received unfair advantages and older classifications have to jump through hoops to be given the same set of assumptions used by newer cars. Nor does the appearance of a conflict of interest does not assist in finding harmony.I will say this. All of this discussion over ITB -- to the EXCLUSION of spending needed time on other IT classes -- is really, really frustrating. Some of it is certainly the historical classing issues in the class, but quite frankly, I don't think I've seen another group of drivers so virulent in "weight advocacy" as the ITB group.
You are on record supporting rules stabilization. That would pretty much mean that task for the ITAC would be the classification of unclassified vehicles and the reclassification of older cars in Accord with the process. ITB and ITC are the places you will find a massive GF of a mess, courtesy of the process. The ITAC has taken ITC off the table pending something, so that leaves ITB as the 600-lb white gorilla. It's also a very popular class.
If that were true, you would set weights based on published HP #s and to hell with RWD/strut/FWD modifiers and to hell with whether the car is a smogged out POS or a lean, mean fighting machine as it rolled out of the factory.Our goal is to get you guys close and let you race. If you want true micromanagement of your weights, well, I agree: go to Prod.
