300lbs of lead in 100lb blocks. Yup. ITR S2000.
Jim Drago has a nice system for the miata , but by the time you add all the weight I need it's $$$$$
http://mazdaracers.com/store/product/57-ballast-system/
Since I'm going to STL , I can move my weight to a better location than the ITA specified location. My current plates no longer fit in the new location , so I need 160# ... I priced out 10"x12"x1/2" plate from
www.metalplatesource.com
With shipping it was almost $ 400.00
John W8
CSP10 Miata
ITA50 Miata
Not exactly. From the GCR
l. Ballast may be used. All ballast shall be located in the front passenger foot well/seating area, aft of the firewall and any foot well angle, and forward of the aft-edge of the forward most passenger door opening, unless otherwise specified on the vehicle’s spec line. OEM front passenger seat location.
1. It shall be in segments no heavier than fifty (50) pounds, and shall be capable of being removed to be weighed apart from the car.
2. Each segment shall be fastened with a minimum of two (2) one-half (1/2) inch bolts and positive lock nuts of SAE Grade 5 or better, and shall utilize large-diameter, load distributing washers.
3. Holes may be drilled in the front passenger foot well/ seating area floor pan for purposes of mounting the ballast (only), and said floor pan may be reinforced as required for the same purpose.
dick patullo
ner scca IT7 Rx7
'92 Honda Civic Si
Confirmed 3 blocks of 50lbs. I even picked these up at the lead guy. 300lbs would have not been good in the Mazda. I was remembering that we thought we needed 300lbs of ballast until Ulfelder did all his do-dads like cool suit etc. Those blocks have about the profile of an iPad.
Go on eBay and do a search for "lead". There are numerous sellers that ship lead using USPS' "if it fits it ships - up to 50#" boxes for $12-$14. So many different forms available, including sheet.
Seems like it's all made from melted-down wheel weights, fishing sinkers, and bullets, and I'm sure the sellers probably don't have any teeth left, but it's your duty as an American to ensure the economy continues to function for these folks.
You do love America, right...?
