I bought used set of Koni Double Adjustables for the the Front and Single Adjustables for the back, that were supposed to fit a MKI.
When I went to bolt up the fronts I see that they are actually MKII housings. Bolt spacing is different and the knuckle is not wide enough. I could fix the knuckle width with a spacer but the bolt spacing won't be as easy.
Before I go modifying them, am I correct in saying that their is no MKI housing that will fit the 8611 inserts? I believe the MKI housing are not wide enough.
