Sure could. Air temp (= density) determines the amount of fuel to provide.
You said this is a fresh rebuild. Any chance you've got an S4 rear iron? That would interfere with the S5 intake and cause a big vacuum leak.Still need to double check for a vacuum leak, and maybe I'll do the FSM test on the water temp sensor.
