Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: 14/15 x 6 Wheels
Hybrid View
    Aug 2003
    Locust Grove, VA, USA
    528
    Default 14/15 x 6 Wheels
    I hate to throw another wrinkle in this raisin, but has anyone been able to find 14 or 15 x 6 wheels under $200.00 each? Plenty of 14/15 x 6.5, but no 6.0s!
    GRJ
    Nov 2004
    Boyertown, PA- USA
    454
    There are quite a few OEM wheels that are that size...
    Matt Green
    Flagtown, NJ USA
    6,335
    GRJ,
    I don't know about brand-new wheels, but I can probably get you at least 20 14x6, 4x100 wheels for $25-$50 each, but the end of tomorrow. Don't know if they're going to be ultra-sexy, 9# race wheels, but every ITB VW ran them, prior to this year. Also, I think new Panasports are only ~$175/ea.
    BTW, I don't think I've ever seen a 14x6.5 wheel. That's not to say they don't exist, just that I've never seen one.
    SCCA 279608
    Aug 2003
    528
    None that fit my car, Matt, and none for a friend's C Rabbit. That we cand find. Point here is, yet another rule that helps a few people in class but not all. And I respectfully submit, if the rulemakers had done a little homework they would have found 6.5's were readily available.
    GRJ
    Aug 2003
    528
    GRJ,
    Bill the info I have says no 14 x 6s, and he's been looking all winter. But if you can identify a source he and I would appreciate it. BTW, the 15 x 6.5's are on Tire Rack.
    It may be the 15 x 6's he's having trouble with.
    GRJ
    [This message has been edited by grjones1 (edited March 06, 2005).]
    8,607
    Mr. Jones beat me to this topic by about an hour.
    I have a garage full of OE VW alloys (16.5 pounds each) but if light wheels were available, the 25# of rotating mass that might be saved could be a meaningful amount.
    The only argument to use 15x6s at this point would be if light wheels could be found more cheaply but it becomes a matter of finding them "at all" it looks like.
    I look at the affordable 14x7 Team Dynamics with envy. Maybe the answer is to standardize the wheel rule for all IT classes.
    Kirk (who is practicing what pols do so well by saying "standardize the wheel rule" rather than "let me use 7-inch wheels.")
    Aug 2003
    528
    Thanks Kirk for making my point much better than I did.
    GRJ
    Nov 2004
    Boyertown, PA- USA
    454
    Well, on the Rabbit thing, look for any 4x100 15" wheels from Chrysler in 84, 85, and 86 (or even later, but a few are 6.5 wide). MOST of the Chrysler 15" stuff from the 80's was 6" wide, and available in 4 on 100mm and 5 on 100mm patterns.
    Granted, both you and Kirk are right that most of those wheels weigh about 16-18lbs each, but there are ways of dealing with that...
    I will certainly back you guys up on the point of no LIGHTWEIGHT 15x6 wheels, but there are options beyond that.
    GRJ- What car do you run again? Was it a Fiesta/Festiva? Are they 4 on 100 or 4 on 4.25?
    Matt Green
    Nov 2001
    Kensington, CT, USA
    1,013
    14x6.5 were common on E30 BMW's.
    15x6, 4x100 wheels are a dime a dozen! - most gen 3 Acura Integra's came with that size. Also the 99-00 Civic Si. So if you can find someone with one of those that decided to get aftermarket wheels (I think that would be about 95% of them) you got yerself a cheap set!
    Aug 2003
    528
    '79 Fiesta. 4 on 4.25.
    Thanks, Matt.
    GRJ
    Aug 2003
    528
    Jake, I don't think the the Acura/Honda or BMW bolt patterns will fit the VW or the Fiesta, And offsets may really be a problem, and of course 6.5's are illegal, but thanks for the info.
    GRJ
    Nov 2002
    Northern Kentucky
    876
    No need to allow B and C to go up to 7" wide. That IS a performance thing and a whole bunch of people (and I'm one of them) would have to liquidate everything they have and buy new wheels.
    Not a good idea. Count me as a "nay" on that one.
    And 14x6/15x6 in 4x100 aren't hard to find at all. Not even light ones.
    Kirk... Try some OEM 14x6 Miata wheels. They are out there by the thousands, some as light as 10lbs each.
    There are also bunches of oem Honda wheels in 15x6, most are 4x100.
    VW
    BMW
    There are LOTS of 6" wide options out there in 4x100, which is arguably the most common bolt pattern in IT.
    George, at the risk of flipping your switch yet again... You drive a Fiesta. That means, and you should know this, that your choices of most everything are going to be more limited than the rest of us. You simply can't expect the ITAC or the Comp Board to say things like "Well, we'd like to change this rule, but it won't help the Fiesta guys at all so we shouldn't do it."
    As I've said before, the new rule doesn't help me one bit because I have to run 13's due to gearing. But I still think its a great idea.
    More options, without changing the competitiveness of what people already have (ie: not changing the width rules), is always a good idea. But these things can't always help EVERYBODY.
    Go ahead George... I know its coming...
    #22 ITC Honda Civic
    3rd Place 2004 ARRC
    1st Place 2004 ARRC Enduro
    www.motorpride.com/Catch22
    Mar 2002
    Black Rock, Ct
    9,594
    [quote]Originally posted by grjones1:
    GRJ
    Question:
    Did you submit a written opinion/comment during the commentary period before the rule was enacted? I seem to remember a lot of discussion, and this may have been mentioned, but I don't recall it. But...the bottom line is, was it brought to the ITACs opinion in writing?
    Comment:
    The rule per se has not treated you unfairly as it hasn't provided other models with a significant or unreasonable competitive advantage while denying you. Granted, it might have made racing more affordable for some more than others, but thats how it goes...we choose our horses and live with the chioce, for better or worse.
    ITA 57 RX-7
    [email protected]
    Nov 2001
    Cragsmoor, NY
    490
    And just to add another thorn into this.....
    try and find "forged wheels" not "cast".....
    Phil Phillips
    2004 Honda Challenge H3
    NASA ECHC CHAMPION
    www.philstireservice.com
  15. #15
    Apr 2001
    NH, US
    3,821
    Here are several 14X6 wheels that are 4X100. Perfect for IT racing... they are cheap!
    http://www.discounttiredirect.com/direct/f...-100*9-100&rw=6
    Here is what comes up for the 15x6 wheels. I wouldn't go for the steel wheel but the other one looks perfect for IT, and its cheap!
    Stephen
  16. #16
    Oct 2001
    Oregon City OR.
    1,550
    Who ever said racing wheels should be cheap?
  17. #17
    Apr 2001
    NH, US
    3,821
    True, but he was just asking for wheels under $200.00 implying that he had already found expensive wheels.
    My Konig wheels I purchased are 14x6 and $53.00 each new. They only weigh in around 11.5lbs making them very light for the price! I love them and I have never bent any of them. IT racing should be cheap, it's amatuer, and REGIONAL at that!
    Stephen
    PS: I think the intention of the rule was just to allow people that no longer had wheels available to them to have other options that gave very minimal competition advantage. I think they intentionally made the rules to only allow 6" wide so people would NOT go out and buy all new wheels because the gains would be very minimal if any. I think the rule should stay exactly the way it is.
  18. #18
    Oct 2001
    Oregon City OR.
    1,550
    True but when you drive a one off car everything will cost more. If cheap where what it was all about them spec small block chevy would be the only class in SCCA...
    "You can please some of the people some of the time and most of the people most of the time but somebody is always gonna be willing to kick yer butt everytime"
  19. #19
    Oct 2002
    newington, ct
    4,182
    If the rules opened the wheels up to 6.5”, many people would perceive that they now need to go out and get the 0.5” wider rims. If you open it up to 7” wide rims, 90% of ITB drivers would feel like they need to get them as well. The current rule as written is great. It allows people to increase their wheel size to allow more choices for the often hard to find rim sizes. I was very fortunate that Jake F. found me some 13x6 rims a while ago on eBay because I found them tough to find.
    While I feel your pain in trying to locate hard to find parts, as previously said, we do choose the cars we race. Because my prelude is pretty uncommon, it is a real PITA to find stuff for it! As frustrated as I get, I know that I put myself in that position.
    Dave Gran
    NER ITB #13
    '87 Honda Prelude si
  20. #20
    Aug 2003
    368
    Honda and BMW wheels WILL bolt onto the Fiesta provided it has a 4x100 bolt pattern. Offset notwithstanding, the only area of concern is the hub size. Honda uses a smaller hub than VW which means that while it's possible to bolt-on a Honda wheel onto a VW, it's a bit more difficult to remove said Honda wheel (ask me how I know).
    That having been said, 14x6 is one of the more common FWD wheel sizes for compact cars. From your tales of woe, I can only assume that the Ford Fiesta has some extremely odd offset.
    I won't dig too deep into the "racing wheels are too expensive" discussion but I will say that with the inclusion of 15" rims in ITA, I'll STILL stick with my 14x7s. 15s would be nice but I can't justify spending the money b/c I already own the 14x7s and they work just fine.
