Results 1 to 13 of 13
Thread: Engine break-in procedure
Hybrid View
    Dec 2001
    steinbach, mb, canada
    242
    Default Engine break-in procedure
    What kind of engine break-in procedures are recommended for IT engines?
    I found this information http://www.mototuneusa.com/break_in_secrets.htm
    Is it accurate?
    My car is able to be registered for street use, so I could break-in like that, or I may also have the option of extensive dyno use, in which case it would likely be better do to that.
    Anyone have experience and recommendations?
    Car is an ITA crx
    Buffalo, New York
    2,942
    Chris--I have done it both ways. My experience tells me that there is no problem with the "hard" break-in.
    Obviously, since I build my motors, I know what was done and have no one to blame but myself if it blows-up. That said, other than starting it, getting the timing set and
    checking for leaks and bad noises, why not put it on the track or a chassis dyno for some hard runs?
    It does seem to work.
    Maybe if I was buying expensive, pro-built motors, I'd feel the gentle break-in is better.
    My car used to be street legal for break-in purposes. Not any longer!
    Cheers.
    Jun 2001
    Milwaukee, WI
    1,193
    My last engine was driven for less than 100 miles on the street before seeing the first track day. When I pulled it apart this winter, the engine was still in perfect condition (so much so that I will be re-using most of the parts in the spare engine).
    I've always been told to break-in the engine the way you plan to use it. I don't have any dyno tests to back any of this up, but I plan to break-in my new engine on the jackstands for about 1-2 hours at different RPMs before taking it to the track.
    Bill
    Planet 6 Racing
    Dec 2001
    242
    Ok I'll probably run through the recommended procedures according to the mototuneusa.com site
    Bill, most everything I've read had emphasized doing the break-in procedure under load, so doing it on jack stands would be a bad idea (according to what I've read)
    can anyone confirm or deny this?
    Jun 2001
    Milwaukee, WI
    1,193
    Chris, I know. But, to put the engine/trans into my daily driver was just too much work and engine dyno time was just too much $$$. I need to run the engine before I take it to the track (problems are easier fixed in the garage 1.5 months before the first event) and it is going to take at least 20 minutes to pump up the lifters.
    Bill
    Planet 6 Racing
    Buffalo, New York
    2,942
    Try a chassis dyno!
    20 minutes to pump up the lifters??
    Nov 2001
    Halifax, Nova Scotia
    639
    Bill's talking about hydraulic lifters...
    Oct 2002
    newington, ct
    4,182
    Wow, I'm surprised there isn't more feedback on this topic. The article's method does seem to make sense. Any reason not to use it?
    Dave Gran
    NER #13 ITA
    '87 Honda Prelude
    Apr 2002
    Bridgewater, MA USA
    1,300
    Dave,
    I am betting the lack of trafiic on this one is simple: everyone has (and has heard) a different opinion on what is right and nobody will convince anyone otherwise.
    I say do what the guy who built it for you suggests. I would hope they can rely on past experience to provide you the best data.
    AB
    Andy Bettencourt
    06 ITS RX-7
    FlatOut Motorsports
    www.flatout-motorsports.com
    Guest
    My engine builder said to put a brick on the gas pedal and run it wide open for a while but I think he had some sort of agenda.
    Buffalo, New York
    2,942
    I Pre-oil them before install; they do not leak down.
    Jun 2001
    Milwaukee, WI
    1,193
    Unfortunately, I stored them in the wrong position, so they did leak down on me. Not the end of the world, as they actually pumped up pretty fast last night.
    Now, if I can just track down that little oil leak...
    Bill
    Planet 6 Racing
    Oct 2002
    Concord, NH 03301
    700
    I asked a guy who did dyno work for an engine shop about break in on the dyno - break in slowly or just slam it after its all warmed up.
    He said just get it up to temperature and give it hell - dyno time & installation time are expensive, if its going to break, get it over with before investing any more than you have to.
