Results 1 to 20 of 116
Thread: STL - what's going to be hot?
    Do you feel there is a big need for alternate brakes? These cars are so sttractively light that I wonder if there is a need...but also can't think of much of a downside except for cost issues.
    I would LOVE big brakes. The miata will be the same weight as my ITA car but have WAY more straight line speed. Chassis wise they will be virtualy identical except for downforce, slow speed corners following a long straight will require much more brake force. Good race pads for Wilwood calipers are also significantly cheaper then pads for the OE brakes.
    I also dont consider the cars to be "so sttractively light", I will need to carry around 300# of ballast and the car is not undergoing a major weight loss program.
    2100 to 2200 pounds would be a better more attractive weight for a 1.8L car, the reason I might still abort and switch to EP or STU.
    Northeast
    7,031
    Quote Originally Posted by tyler raatz View Post
    I for sure get they would be 'better' but wonder if they are needed as all. I glossed over the 300lbs when we talked earlier. At about 2450lbs of car why would you need to add that much?
    New England Region 188967
    The weight is actually 2398.5#
    To make ITA weight 2380#, I have between 150-180 punds of ballast depending on fuel load, cool suit etc.
    Build lighter tub, remove HVAC system, remove all excess wiring, remove all the BS parts required by IT, lighter hood, lighter trunk, lexan, etc.
    Yea, I'm gonna have 300# of ballast.
    Dec 2008
    1,391
    the brake thing has a few huge potential upsides.
    1 - increased partiy. currently chassis can be chosen as much for their handling characteristics as they can for their ability to bolt on stoppers and drop in motors. 2.0L cars will be HEAVY and bigger brakes will make them more attractive - more cars become "competitive", at least in theory. Also, you will have a good variety of pads available no matter what car you choose, and they will be lower cost. no more shipping pad backings to carbotech for custom rears on the fugizit. just get the superlight compound of your choosing.
    2 - simplification. and it's not expensive after the buy in. pretty much like everything else in the class.
    3 - category cohesiveness. STL DOESN'T LOOK like ST. it looks like IT. this will take it a step towards matching its bigger brothers and not looking like the mailman's kid.
    4 - speed. we're looking at a LOT more speed than factory binders are made to slow. we all recognize that all motors of similar displacement are not created equally, even within the class allowed mods. what is certain is that speeds will be a lot higher than similarly bodied IT cars. give them the mass in the braking system to cope with that.
    downsides:
    some work. less IT-ish if you care about that. other than that...
