What were you thinking?
Looks like we'll have at least 16 races, depending on how the double/triple weekends shake out. Minimum 8 races to be crowned?
I always thought that point systems were backwards. I know we as humans think that bigger is better, but it's so much easier to do things backwards...and with less digits.
How about this: One point for each position. Points are bad. Lowest at the end of the season wins. Example - First place gets one point, 12th place gets 12. A theoretic perfect season would be 16 points.
Using the above points system, maybe you get a point or two added for each race that you don't start. So if you attend 12 of 16 races, you get 4 points added to your score. This system could work even with the existing points system.
