My list keeps getting longer:
1 make some changes to the cage
2 build a better exhaust
3 convert motor to later electronic injection and megasquirt
4 change bent rear axle
5 fix banged up right side of the car
Then 6 comes up. Found a really clean shell locally. Decided to pick it up and build a better version of my current car. After 2008 I really believe that an all out fresh build is what I need to meet my goals. Just need to make it a little bit better in every category.
It will probably drag out long past winter, and may preclude me running at all in 2009, but I look forward to the process, and driving the result.
GARY, that son of a gun looks like it just came off the showroom floor! Can't wait to see the blue streak going around Hallett.
Mac Spikes
Cresson, TX (Home of "The Original" MotorSport Ranch)
"To hell with you Gen. Sheridan...I 'll take Texas!"
There's not a lot of major items to do on the car so I have a short list of things I'd like to get to if time permits.
- Have the spare engine ported, rebuild and swap it sometime mid season if I'm behind in the points.
- install jacking plates
- reinforce the shock and strut towers
- tab the shell to the cage
- reinforce the subframe
- install racing transmission
- relocate battery to the trunk
- fiberglass bumpers
- 8" rims
It needs a good waxing too.
Tom Sprecher
Switching from carbs to fuel injection. Lot of work. Lot of money. Hope it pays off.
Gary, your Volvo is cool, always loved that body style! Tom your blue car is nice too...gotta love a clean RX7.
My list:
Put together a new engine - I'm about 40% there, still cleaning and measuring parts
Pull my existing engine, replace the front and rear seals e-shaft seals, replace the front cover gasket and clean it up a bit.
Replace the Pitman arm and innner/outer tie rods...The pitman is a touch loose and the tie rods are old
Make ride height checking fixtures so that I can use the Hunter Lazer Alignment system at Santa Fe Garage Services to setup the car for next year
Replace the front rotors, bearings and pads
Pull the radiator and oil cooler and clean debris out of the fins
Unbolt the front fenders and clean out the tire rubber
Replace some of fuel lines in steel braided
Rework my helmet blower hoses
Service and inspect everything else
Save for tires..................
Scott Peterson
KC Region
83 RX7
STU #17
