Reading and learning alot. Have decided to run shaved Toyo RA1's for dry, Hoosier Hwet for wet. 500lb springs in front, 600 lb in the back. On order
Currently looking at installing an adjustable larger sway bar in back. Of course
none exist for my car so I will get components from Speedway Engineering and fab one up. Question is what type of bar, solid, hollow, diameter, I guess it all depends on what wheel rate you want. Is there anyway to determine an approximate wheel rate required for a car. I am not sure of the attachment points yet so arm length is not final. Do you have to use same attachment points? My current bar has arms only 6" long.
