contact me at 570 262 1013 and i'll get the hardware.
the head bolts can be reused. they are not torque to yeild type which is a one shot deal. there is no harm is using brand new ones, just added expense.
the rod bolts and nuts NEED to be replaced every time the bottom end is redone.
also, what other items are you replacing???? oil pump, oil cooler (not sure if the front drive platforms had the same cooler thats on the miata), etc.
