Results 1 to 20 of 230
Thread: Teach me about ITR 325's
    Quote Originally Posted by Doc Bro View Post
    What part of 'bushings are free' am I misunderstanding?
    The part about them being under the category rules for suspension...?
    Of course, if we're agreeing that any bushing that suspends anything is free, let me know...'cause you ain't gonna like the results...just sayin'...
    GA, who's really hoping our BMW friends are not replacing their rubber caliper bushings with anything non-rubber...
    Sep 2004
    cromwell ct
    746
    Mine are stock, but I thought this went back and forth several years ago...with the end interpretation being bushings are free. I could be mistaken. I thought it was around the whole spherical "bushings" and "air bushing" era.
    From the GCR;
    bushing- a sleeve or tubular insert, whose purpose is to reduce the dimension(s) of an existing hole. A protective liner that cushions noise, friction, or movement such as a rod end or spherical bearing.
    The suspension section clearly states bushing material is unrestricted as we all know.
    The brake section states that brake linings are unrestricted....what's the difference between a liner and a lining?:cool: Brake connectors are unrestricted. Isn't a connector something that "connects" the something to something else? As in the caliper to the car? Seeing how lining and connector aren't defined in the GCR I'm unsure.
    I think this subject is pretty gray...as I stated before mine are stock so don't be a hater....just posing a counterpoint.
    R
    Rob Breault
    BMW 328is #36
    2008 NARRC DP Champion
    2009 NARRC ITR Champion
    2009 Team DI Pro-ITR Champion
    Jul 2006
    Silicon Valley, CA
    1,381
    From the GCR;
    R
    I find that all to be a ridiculously tortured interpretation.
    A brake lining is the actual brake pad/shoe material. The "connector" being referred to is the hydraulic connector. That entire paragraph is about hydraulics. Context matters.
    Not even remotely gray in my opinion.
    Josh Sirota
    ITR '99 BMW Z3 Coupe
    Northeast
    7,031
    Quote Originally Posted by JoshS View Post
    +1.
    New England Region 188967
    But if it is, please do let me know ASAP.
    Sep 2004
    cromwell ct
    746
    But Josh those are YOUR definitions not the GCR's, The GCR doesn't define these things so variability (creep) gets introduced.
    SoI guess the ITAC guys get to decide what's rediculously tortured...
    Let's go back to "air as a bushing" and truly talk about what's tortured.
    R
    Rob Breault
    BMW 328is #36
    Jul 2006
    Silicon Valley, CA
    1,381
    Of course these are all just my opinions. In my current role I don't get to decide this stuff. But in the past I have served on both protest and appeals committees, and I know how the committees that I have served on would have interpreted these situations. I think that 99 out of 100 appeals committees would agree with me. Unfortunately, too often, these things never get protested/appealed.
    That past experience is part of why I have such a conservative read on the allowances.
    Josh Sirota
    Northeast
    7,031
    Oye. Looks like it's time to tear some cars down in NER.
    Sep 2004
    cromwell ct
    746
    Quote Originally Posted by andy Bettencourt View Post
    oye. Looks Like It's Time To Tear Some Cars Down In Ner.
    +100
    While were at it we should clean up the on track antics as those have gotten out of hand too.
    R
    Rob Breault
    BMW 328is #36
    Tijeras, NM
    579
    Ridiculous. Not even remotely legal, or gray.
    Tijeras, NM
    579
    Oh come on.. those bushings suspend the calipers right? Give me a break. Anyone remember when they tried to justify internal coatings because they were "lubricants"? That didn't fly either.
    Sep 2001
    alexandria, va
    851
    some folk have trouble wih engish. suspend as a verb vs. the gcr use of suspension as a noun...
    Aug 2007
    Northern, CA
    217
    Does anyone have a link to the bushings you guys are talking about?
    Mike Uhlinger
    Jul 2006
    Silicon Valley, CA
    1,381
    Quote Originally Posted by ekim952522000 View Post
    Here you go Mike:
    http://www.turnermotorsport.com/html...ODUCT_ID=CBMW1
    The issue is that all of these cars have single-piston sliding calipers, and the caliper slides on metal pin, but with a rubber bushing. The brake can feel really squishy and cause uneven pad wear due to the flexibility in the rubber, especially as the pads get low and the piston is extended.
    These metal replacements are very common for track cars and BMWCCA club racing.
    Josh Sirota
    Sep 2004
    cromwell ct
    746
    Quote Originally Posted by GKR_17 View Post
    And air as a bushing is justifiable in your mind....give me a break. Is air then justifiable as a washer bottle or wiring harness in your mind?
    R
    Rob Breault
    BMW 328is #36
    Northeast
    7,031
    R
    Can you cite someone/some car who actually does this and claims it's legal? I think it's bantered about but in reality it's internet folklore.
    Sep 2004
    cromwell ct
    746
    No AB. I know no one. But I remember the discussions about it ad nauseum, as I know you do.
    My comments were only directed at the fact that the GCR offers no clarity on the questions I posed. Next thing you know I'm a rules creeper. As I stated mine are stock rubber, period. Reminds me of the RX7 1st gen rear wing guy.....easy to see why he made the mistake....even easier to see why he got beat up here. I guess I learned my lesson....I'll spend more time with my family and less time on IT.com. I'll let the "pro's" chase windmills.
    R
    Rob Breault
    BMW 328is #36
