Results 1 to 18 of 18
Thread: New STL Fan
    Aug 2005
    1,717
    By that reason, the 325's M20 normally called 2492cc motor is actually a 1247cc's because that's what it uses in one revolution of the crank, so it's STL legal then
    STU BMW Z3 2.5liter
    Even though the 13B may have 1300ish cc's of actual volume it acts like a 2-stroke. So they class it effectively as 2.6L because it has twice as many power strokes per revolution as a conventional piston engine...1 power stroke per rotor every revolution whereas the CPE has 1 PS every other revolution.
    Right!
    And if one wants to get pissy about it...go read the GCR Technical Glossary definition (which I don't agree with, and tried to get corrected...)
