View Poll Results: I would like the IT rules to allow removal of dual purpose vestiges.
Voters
131. You may not vote on this poll
  • Yes.
    76 58.02%
  • No
    55 41.98%
Results 1 to 20 of 310
Thread: A Poll Regarding the IT Rules Set
    Dec 2005
    Port St. Lucie, FL
    354
    I've tried, but I just can't contain myself anymore.
    What Cameron said! lol......
    I would agree with that as well. I only pointed out the ECU as an example of creep and something more threatening than a wash bottle, but it's done and we can't go back. If we are going to creep we gotta creep fairly. It's probably best (meaning most fair) that all the sensors be open.
    raleigh, nc, usa
    5,252
    I have too much of a vested interest in the sensor rule to debate it objectively....I'll leave that one to you guys.....
    Black Rock, Ct
    9,594
    Quote Originally Posted by spawpoet View Post
    ..... ECU as an example of creep ....., but it's done and we can't go back. .
    Just curious, should the ECU rule (assuming it never opened) remain "stock"?
    Dec 2005
    Port St. Lucie, FL
    354
    I think it was pointed out before that some ECU cars had no way of getting around rev limiters etc (that are integral to stock units) without changing/modifying the ECU's, so I'm not sure opening of ECU's could have been avoided. Call it inevitable creep. The cars we race have changed, and the rules have to change with them. As long as all cars are kept as close to equal as possible that is all we can ask for. I (selfishly) don't want to see carbd cars left behind as ECU's have opened up, but at the same time I don't see yet where they really have been. I.E. I see well built, well driven versions of my carbd car as currently competitive.
    raleigh, nc, usa
    5,252
    In the last 18 months, I've done way more reading than I wanted to on EFI v. carb. I had to make the choice to spend the money to do the conversion on the TR8.
    My car is a bit unique because the FI intake manifold is significanlty better than the carb one, which gives peak gains that would not be there otherwise.
    Which leads me to my core point. EFI is not "magic." At the end of a day, and this is backed up by all kinds of data from muscle car land, EFI will probably not make any more peak power than a carb'ed car.
    What EFI does give you is, at least in my case, more torque and far more area under the curve via being able to more precisely tune timing and mixture across the rev range.
    Carbed cars can do this is "rough" fashion via messing with the advance curve and the neddles/jets, but it is always a trade off (better in one area of teh RPM than another, etc.).
    But "old school" ECUs can be VERY bad. Mine in particular, which doesn't fuel over 4500 rpm on purpose and has a terrible stock advance curve for emissions reasons.
    Based on this, for my car anyway, the way these things line up is:
    "Open" EFI is significantly better than "open" Carbs which is WAY BETTER than stock EFI.
    Where I am going with this is that I think many stock ECUs would actually be at a disadvantage to carb'ed cars wthout the ability to tune fuel and timing.
    Make of that what you will. If we went back to stock ECUs, I'd have to ditch the ($15k) EFI conversion I did and go back to carbs.
    Jan 2006
    Rockville, MD
    274
    The Weber carb that is allowed for some IT-B cars has sequentially opening throttle plates. Within the present rules, changes can be made to idle air bleeds, main jets, air correctors and emulsion tubes. No matter what you do within these rules, the carb still goes a bit lean at high RPMs or runs like crap in the mid range. Since ECUs are free, shouldn't the drivers of these Weber carbed cars be allowed similar freedoms? High speed enrichment holes drilled into the carb body and concurrent opening throttle plates? If so, some of the existing cars will go faster and others won't. Just sayin'....
    Chuck
    Northeast
    7,031
    Quote Originally Posted by callard View Post
    Chuck
    While I agree that cars with ECU's are able to tune significantly better, is it my imagination or is there a significant % of the cars with carbs making way more than 25% over stock? Think about that for a minute. While under a microscope they may be at a 'disadvantage', when you look big picture, they may be enjoying some power advantages (some of them).
    Listen, I would take EFI over a carb any day (assuming you can get both to work right) but given the era that some of these cars came from, I bet they make a good bit of gains percentage-wise. We just did a request that asked to be re-run and the resultant weight was NOT lower.
    New England Region 188967
    Nov 2004
    Lilburn, GA
    597
    As to sensor ease of installation/usage, no, the Process doesn't parse car models that fine. It is (the sensor package) under discussion.
    Since ECUs are free, shouldn't the drivers of these Weber carbed cars be allowed similar freedoms? High speed enrichment holes drilled into the carb body and concurrent opening throttle plates? Chuck
    These are just from this last page. I didn't include JJJanos' sarcastic comment about the weighting process. Apparently he would like to spend all his time researching cars, motors, ECUs, etc. so that he can more correctly weight them. While he has valid arguments, at some point you have to say we've done the best we can. I think we've reached that point.
    That sound you hear is the vortex spinning faster. Leave IT the f alone for at least a little while.
    ITA 240SX #17
    Atlanta Region
    Dec 2005
    Port St. Lucie, FL
    354
    "Listen, I would take EFI over a carb any day (assuming you can get both to work right) but given the era that some of these cars came from, I bet they make a good bit of gains percentage-wise."
    You mean the Mesozoic era? What you are saying is entirely possible. All we can ask is that significant variables between cars are either equalized within the rules (allowing all ECU cars free run on there sensors), or accounted for through the process. If the antiques have more power potential the process should account for this factor as much as it should account for the advantages of FI vs. carbs. In this case how would would you equalize a 280z with FI, with 240 and 260z's that have carbs? Engine architecture is the same, and supposedly the 280 has better flowing options in terms of head design (though lower comp.) and of course greater displacement.
    Dec 2005
    Port St. Lucie, FL
    354
    "Where I am going with this is that I think many stock ECUs would actually be at a disadvantage to carb'ed cars wthout the ability to tune fuel and timing."
    This is appropriate to one question I am asking. When weights were set for cars pre-open ECU was the fact that carbd cars had more tuning capability at the time factored in to how they were processed or have carbd cars had an edge all along?
