Results 1 to 8 of 8
Thread: it throttle body
    Mar 2013
    13
    the mod I did was just take the cruise control portion off of it. got in the way of converting to megasquirt(fuel pressure regulator)
    Quote Originally Posted by jetta1987 View Post
    As along as it's the same thing that the factory delivered without cruise, you're fine.
    Mar 2013
    13
    well I guess I will see what happens. only other way around it is to change to mk1 intake where the throttle body is on the other side , im using 88 jetta fuel rail and injectors and the bottom sping assembly was getting in the way of the fuel regulator. that's why I removed it. only one way to find out and that is to try right?
    Wheaton, IL
    1,893
    Are you using the 88 Jetta pressure regulator? It should clear fine. If not, I am sure there are pile of non cruise control TBs out there for cheap.
    Chris Schaafsma
    Golf 2 HProd
