Results 1 to 20 of 74
Thread: Head & Shoulder Restraint Kit
    Jun 2006
    Londonderry NH
    157
    I am thinking that the center net would be effective in restricting arm movement, but cannot imaging it retraining head movement. I use a Hans that restricts forward movement but imagine without side restraints that the head is tossed about severely in an incident.
    Jim Alley
    1990 ITA Miata
    Its all about doing your personal Best
    Jul 2008
    Vermont
    721
    Quote Originally Posted by jimalley View Post
    Jim....If the Kirkey head and sholder restraints are anything like the Butler Halo system(and I think they are) they should be a welcome addition to your safety items! Just look at the shunts they have in NASCAR(like the one at Daytona where the woman walked away from an upside down crash and series of flips last week). As regards exit from the vehicle, as they say down south "if you ain't alive, ya'll ain't goin nowhere anyway".
    Practice your exit with halos...it may not be pretty but you'll make it out if the halo saved your life to start!
    Sep 2001
    hampden,ma.usa
    3,083
    Actually head movement is what the right side net is all about. It is set up to catch your shoulder and helmet so they stop movement in the same plane if you get a big right side hit. When I asked around a few years ago I was told that nothing gives you better protection for such a cheap price. I have actually been thinking about one of those sprint car nets for the left side.
    dick patullo
    ner scca IT7 Rx7
    Royal Oak, MI, USA
    1,599
    Quote Originally Posted by dickita15 View Post
    Stop thinking about it, and do it!!! There's NO excuse!!! They're dirt cheap compared to the improvement in safety - just like upgrading from the stock 3-pt belts to a proper 6-pt setup!
    Vaughan Scott
    Detroit Region #280052
    '79 924 #77 ITB
    #65 Hidari Firefly P2
    www.vaughanscott.com
    Wauwatosa, WI, USA
    2,658
    Lets see now. For 2011 all SCCA drivers SHALL wear a SFI 38.1 H&N restraint. With the Isaac I own not SFI rated I'll buy (not happily) a Defnder which frontal load equals the Isaac & HANS while also greatly reducing the lateral load which the HANS does not do. No right side net required.
    It's a laugh that the CRB/BoD recomends a right side net while not allowing the Isaac because of the one release rule. Yes I understand the window net rule to keep the arms inside the car. < This rule came long before the H&N restraint.
    Dito on the silly unsuported head "restraint flaps" that may be added to the seat. Watch one video of the head during a crash you'll understand. The flaps resist minimal lateral load.
    Have Fun ; )
    David Dewhurst
    CenDiv Milwaukee Region
    Spec Miata #14
    Sep 2001
    hampden,ma.usa
    3,083
    actually 2012 but I get your point David.
    dick patullo
    ner scca IT7 Rx7
    Jun 2006
    Londonderry NH
    157
    David- I was not aware of the Definder, but I am now going to research it more as it seems like a more positive solution than some of the other alternatives for restraining lateral movement.
    Jim Alley
    1990 ITA Miata
    Royal Oak, MI, USA
    1,599
    Actually, the center net should be installed to spread from the shoulder to the CG of the helmet, catching both. I used to have a pic on my website showing this, lemme see if I can find it...
    Some pics here...
    http://vaughanscott.com/construction/safety.htm
    OK, not a perfect picture, but should give an idea about the install config.
    Note that I'm not fully cinched down in the seat yet - will sit a bit lower than even that. Plus the camera angle's a little high. When I lean over to the net, it does contact my helmet.
    I've "used" it in this config, too, having been t-boned by a Volvo at the ARRC in '08. Worked like a charm, drove it away and completed the race.
    Vaughan Scott
    '79 924 #77 ITB
