Results 1 to 20 of 128
Thread: Your Thoughts on Mandating 200+TW "Street Tires" in Improved Touring?
    Sep 2001
    hampden,ma.usa
    3,083
    Quote Originally Posted by Rabbit07 View Post
    I road race because I like going around corners fast. As fast as possible, that's a step backwards using 200 TW tires.
    Chris, that's great, looking at your signature line you would still have 3 other categories to race in on DOTs. Plus a forth that i do not know what it is. why not have some differentiation between categories.
    dick patullo
    ner scca IT7 Rx7
    Purcellville, VA USA
    902
    Quote Originally Posted by dickita15 View Post
    Someone on the CRB or BOD thought it was a great idea to dump SS and replace it with Touring 4 and Bspec. Not sure we are further a head at this point.
    I understand the differentiation of classes part. You could get me to the middle on that. The idea that this will save $ is ridiculous. We got here due to tire wars to compete in a DOT class. All you'd be doing is hitting the reset button and it would start all over again. No thanks
    Chris "The Cat Killer" Childs
    Angry Sheep Motorsports
    810 417 7777
    angrysheepmotorsports.com
    Oct 2005
    In the green Honda
    449
    You think going to 200 tires will start a DOT tire war in IT? Now that is funny.
    Jim Hardesty
    There are two primary reasons I see 200TW tires being useful to Improved Touring:
    1) Category Distinction and Differentiation. What differentiates IT from other categories? Prep isn't massively different than LP Prod, and Touring is inching - leaping - its presence away from its Showroom Stock roots. IT tires are no different than Touring or Super Touring. IT doesn't have wings and splitters are limited. IT does not go to the org's biggest event of the year.
    If asked to explain why run Improved Touring instead of any other class, what's your answer?
    200TW tires would clearly differentiate the category in a significant way, something that is not done by any other category.
    2) Attraction from other groups. There is a large and growing population of racers out there in series and with orgs that do not allow tires with a TW lower than 200. Limiting the class to 200 makes it attractive to them. Those orgs do that specifically for costs purposes. No one can legitimately argue that a $250 10-cycle tire can ever cost less, long- or short-term, than a $120 more-than-10-cycle tire. And while outliers can never be eliminated (really, you're going to shave your tires so low that they'll only last 2 sessions?) they can safely be ignored. Because outliers are not for whom we make decisions.
    Improved Touring needs to make positive changes that will differentiate it from the existing crowd and make itself attractive to those not interested in chasing the Runoffs-of-the-Year. And this would be a really easy and cost-effective way to do it, one that would be quite easy to revert if it didn't work out.
    And, really, 3) because those that actually want to spend the big money on consistently replacing fast tires probably don't really give a crap about Improved Touring anyway...
    Food for thought.
    May 2003
    Lagrangeville, NY
    694
    Food for thought.
    I was thinking no on this idea until Greg's post. I'd like to try it.
    (even though it may make double dipping difficult)
    Chris Raffaelli
    NER 24FP
    Jun 2001
    Pickerington, Ohio
    760
    The crossover argument doesn’t hold water. Cars from other series (Le/Chump) aren’t prepped to IT rules. So for them to run in an IT class, they require modification to even be legal. And many of them have taken the cars well past the point of being ‘returned’ to IT legal. Cars that successfully make it to legal, will (probably) be closer to stock/legal than built/legal. Tires won’t make them competitive. Having an IT(ez) class for cars from these series to run in seems like the best option to promote crossover. No changes required (or veery minimum) and they all compete on 200tw tires. Competitive with ‘like’ cars and can try SCCA.
    Requiring 200tw tires will limit crossover within SCCA (that is already happening). Spec Miatas will need multiple sets of rims with different tires to run both ITA and SM. Other IT cars will need the same to double dip with STL, STU, and Prod.
    I’ve spent a fair amount of time running ITA. When I was winning or at the front of the pack (minus Mosers and Ruck), I ran hankooks. Guys chasing me were on Hoosiers. Tires are important, but there’s much more to being competitive than tires.
    I’d ask: What’s the problem we’re trying to solve?
    If it’s how to get crossover from other series, we need to look at license requirements (having run some Chump, you don’t want most of those folks participating without at least a little formal training). Then look at car classifications and determine the best path requiring the least modification for these cars.
    If it’s controlling costs in IT classes, as many have said, you can’t keep people who want to spend money from spending it. Limit one area and they will spend in other areas. Good to look at options to control cost, but this tire mandate could actually increase costs for those crossing from class to class.
    If it’s something else, I’d like to know what it is. It feels like we’re trying to justify a solution without firmly identifying the problem.
    Matt Downing
    1995 Honda Civic EX Coupe - ITA
    Ohio Valley Region, SCCA
    Oct 2005
    907
    Quote Originally Posted by downingracing View Post
    Amen! Hallelujah! Exactly.
    Oct 2005
    907
    And this matters why?
    My apologies. I thought you were making a serious proposal. The tell was when you said racers won’t waste money to gain an advantage and we don’t create rules for outliers.
    That is why we do not have the full range of blingy shocks that come with even a time-zone adjustment.
    That’s why we do not have fuel testing because nobody is going to spend $75/gallons to win a race.
    That is why we never worry about someone cheating because nobody would want to win that way.
    ChumpAER guys are not skipping SCCA because of purple crack. They skip us because our rules are immense and restrictive. They can also turn any POS dog into a better car by doing loads of modifications to make it competitive in a new bracket.
    Not going to shave tires? Pull the other leg! That is the one with bells on it; you will get to her the ding.
    Showroom stock guys, back in the day, shaved their tires like it was a first date. Look around the paddock — the drivers may have changed, but they are just as stupid about gaining an unfair advantage as the old bona-fide SS drivers.
    You mean that I will need to spend a boatload of money on new wheels, a new final drive and suspension setup and reserve the right to say “Psych!” Thanks!
    I appreciate the effort to do something for a category that probably received a death blow from Topeka siphoning away our entrants, but be realistic about how stupid drivers are when it comes to an advantage.
    Chicagoland, IL
    213
    This is what I meant by mandating 100TW + tires. There are viable and inexpensive solutions for us that are not 200TW. In fact the Maxxis 100TW option as far as we have been able to tell is a really great race tire, does not heat cycle out and a set now 2 years old is only getting replaced because the cords are showing!!!
    HOOSIER RADIAL WET H2O Wet Racetrack & Autocross Only
    UTQG: 40 C A
    TOYO PROXES RR Racetrack & Autocross Only
    UTQG: 40 C A
    HOOSIER R7 Racetrack & Autocross Only
    UTQG: 40 C A
    HOOSIER A7 Racetrack & Autocross Only
    UTQG: 40 C A
    HANKOOK VENTUS Z214 Racetrack & Autocross Only
    UTQG: 40 C A
    UTQG: 40 C A
    BFGOODRICH G-FORCE R1 S Racetrack & Autocross Only
    UTQG: 40 B A
    TOYO PROXES RA1 Racetrack & Autocross Only
    UTQG: 100 AA A
    TOYO PROXES R888R Racetrack & Autocross Only
    UTQG: 100 AA A
    Nitto NT01
    UTQG: 100
    Maxxis Victra RC-1 DOT-approved R compound
    UTQG: 100 A A
    Maxxis Victra VR-1 Extreme Summer tire
    UTQG 200 AA A
    TOYO PROXES R1R Extreme Performance Summer
    UTQG: 200 AA A
    NEXEN N FERA SUR4G Extreme Performance Summer
    UTQG: 200 A A
    KUMHO ECSTA V720 Extreme Performance Summer
    UTQG: 200 AA A
    HANKOOK VENTUS R-S4 Extreme Performance Summer
    UTQG: 200 AA A
    BFGOODRICH G-FORCE RIVAL S 1.5 Extreme Performance Summer
    UTQG: 200 AA A
    Racer of old BMW's.
    MCSCC ITS Class E30 325is
    Racing where IT still exists: http://www.mcscc.org/
    Quote Originally Posted by kgobey View Post
    UTQG: 40 C A
    UTQG: 40 C A
    UTQG: 40 C A
    UTQG: 40 C A
    UTQG: 40 C A
    UTQG: 40 C A
    UTQG: 40 B A
    UTQG: 100 AA A
    UTQG: 100 AA A
    UTQG: 100 A A
    UTQG 200 AA A
    UTQG: 200 AA A
    UTQG: 200 A A
    UTQG: 200 AA A
    UTQG: 200 AA A
    UTQG: 200 AA A
    IT7 runs the Nitto NT01 which is a 100TW R...you can add that to your list.
    Jason Carroll - NER IT7 #07
