Originally Posted by
Greg Amy
Intentional, to keep STL from poaching away ITS drivers. It was a double-dipper "gimme", not an intended performance evaluation.
Huh?? As Ron noted above (and has been noted many times previously), setting the RX7 weights at their IT level makes little sense given the STL philosophy - basically "IT-with-engine-mods". All the non-rotaries get more horsepower from cams and compression and many of them get weight reductions, while the rotaries get -- absolutely nothing. Based on your 12lb/whp baseline, the ITS RX7 ought to come in at maybe 2160 and the ITA RX7 at around 1560 (!!). Plus RWD adder, of course. So the rotaries are at an absurdly high weight if the stated philosophy were being followed. (2680 vs 2225 for 13b and 2280 vs 1600 for 12a.)
But of course it isn't. But the "keep STL from poaching ITS" rationale is laughable. Considering practically every STL eligible car is an ITS (or A or , why is it necessary to give RX7s such "special" consideration? Is any one worried about poaching Miatas (or CRXs or Integras) from ITS or ITA? It seems the real reason is that, for whatever reason, some people don't want rotaries in their class (except as IT level field-fillers). If that's so, why not just be honest and allow them in as IT cars along with the SMs and be done with it, instead of pretending they are being admitted to the class on the same basis as other cars?
Or am I supposed to be thankful that the request to increase the weight of the rotaries got turned down?
Tom Lyttle
Decatur, GA
