Originally Posted by
Greg Amy
The ITR chassis reinforcements are fairly irrelevant in STL, given no restriction on cage points and allowance for seam welding. If we did allow it, the B18C5 would maintain its exclusion in the class. Built to STL prep, the only functional difference between a Type R and a RS-sourced build would be the 5-bolt wheels, for which you'd have significantly fewer (and probably more expensive) options for wheels.
If someone wants to take a rare Type R and put in a K20 or a GSR engine to go run STL, knock yourself out. Silly, but whatever.
And, to the general point (I wonder if we'd like to move these chassis discussions into its own topic, and hash them out further there? Edit: done. - GA) if the only major problem with STL regs is what chassis should/should not be included/excluded, then that's actually not an insurmountable problem. It's something easily discussed, changed (even within the "rules year"), and accommodated.
