Back on Topic for me too:
So Earl, the only way this car will be competitive is if it can out-perform it's process power and handle better than everthing in a straight line. I don't see how you can't draw a direct parallel between this car and the Sentra SE-R / NX2000. That car, with ~155whp, is about 75lbs 'light' by the numbers.
I would build it if you were 100% confident that 125whp was possible (5% over the 'expected' 30%). THAT is a butt-load for an ITB car, especially at 2380lbs of process weight.
My presonal recipe for a great IT car is one that HANDLES better than anything else, then try and make process power. Our S2000 is an example of this. I would build a Boxster too. In ITB, I would build a Honda with a DW front if I wasn't such a fanboi of the Corolla GTS (knowing it woudn't be competitive because it can't make process power).
Actually, the best car for me in ITB would be the 924. But only a few guys in the country who have done it so it's an adventure. Honda or VW in ITB is the easy button.
