Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: strapping the car down
    May 2003
    Lagrangeville, NY
    694
    I use a 2” ratcheting 10000# strap (Home Depot, $15) on each of the front OE tow hooks to a D ring on the front of the trailer. On the rear, I do the same thing except around the lower arms.
    My plan is to make the front straps a fixed length and only ratchet the rear (Dick, thanks for the idea). Cuts down half my work and keeps the car in the same spot every time.
    Chris Raffaelli
    NER 24FP
    Jan 2006
    219
    Quote Originally Posted by raffaelli View Post
    Kind of makes it a pain in the butt pulling off the trailer, as you have to move the car forward before you remove the front straps.
    -Tom
    ITA Integra | 05 Mazda3 | 03 Mini
    http://www.tomhoppe.com
    WI
    164
    I have a similar setup with two fixed length straps on the front of the car which get attached first and then I pull the car back with the ratchet straps. Works well and allows me to quickly get the car positioned properly. The drawback is that very seldom is the car in the exact center of the trailer (width) so I always have one front strap that is tight and one that is slightly loose. Never been a problem but not ideal..
    Nov 2003
    Madison, MS
    132
    Quote Originally Posted by ITC Racer View Post
    That's exactly what I do, except my front straps are chains. My car is light, never had a problem.
    Wauwatosa, WI, USA
    2,658
    Using one OEM tow loop front and rear I use a fixed lenght chain at the rear. Pin and clevis at the OEM rear tow loop and chain hook around 2 x 2 x 1/4 trailer angle iron open trailer. At the front I use a pin and clevis at the OEM tow loop with a logers over center lever with a chain hook around a 2 x 2 x 1/4 angle iron. By tightening down with the tow loops the suspension is taken out of the equation which I believe is a good thing. Less shock and spring movement. The chains have NEVER been found loose and the car has never moved in any direction while on the trailer.:cool:
    Have Fun ; )
    David Dewhurst
    CenDiv Milwaukee Region
    Spec Miata #14
    Nov 2005
    Nebraska City
    223
    Quote Originally Posted by ddewhurst View Post
    Using one OEM tow loop front and rear . . .:cool:
    State law (not sure about Federal DOT) here requires FOUR load securement points.
    But whatever method you use, be sure you at least meet the letter of the law.
    Dave Webb
    Bare Bones Racing
    '84 VW GTI
    #17 ITB
    Feb 2003
    Grove City, OH, USA
    1,449
    +1 fixed straps in front, around lower a-arm right against the point where they are mounted to the frame (not the wheel end). Axle strap around the solid beam rear axle to a ratchet. All straps clip to individual D-rings. Trailer has ramps for wheels and has no deck, so getting under to attach straps is not an issue.
    Bill Stevens - Mbr # 103106
    BnS Racing www.bnsracing.net
    92 ITA Saturn
    83 ITB Shelby Dodge Charger
    May 2003
    Lagrangeville, NY
    694
    Quote Originally Posted by trhoppe View Post
    -Tom
    I find pushing the car an inch or two is alot easier than monkeying around with two more ratchets and a balance spot.
    Chris Raffaelli
    NER 24FP
    Tow hooks are strong on the Hondas.
    Nov 2005
    Nebraska City
    223
    I use the same straps in front but the ratchet is welded to the frame. One end of the strap is fed through the front wheel (this is on both wheels) and both ends of the strap are then fed through the ratchet and tightened down.
    The rear is secured with a fixed length chain (although it's adjustable if needed). On severe stops or emergencies maneuvers the chain will prevent the race car from moving forward. No possibility of straps coming undone or a broken ratchet.
    (Lael, thanks for the idea and quality build.)
    Dave Webb
    Bare Bones Racing
    '84 VW GTI
    #17 ITB
    Jan 2003
    Los Lunas, NM, USA
    682
    I use a 2” ratcheting 10000# strap (Home Depot, $15) on each of the front OE tow hooks to a D ring on the front of the trailer. On the rear, I do the same thing ...
    Are those the yellow nylon straps? I'd be careful with those, if they are the ones I'm thinking of, the kind truckers use to strap loads down to a flatbed.
    There are two problems with that kind of strap. The hook doesn't have a safety catch, so if the strap goes slack for a moment the hook can fall off your car or out of the D-ring. Second, although the UTS of those nylon straps is plenty high, they will stretch more than real polyester car straps.
    How do I know this? I used to use those (yes, from H-D) at all four corners of my car. Years ago I was towing up a rural highway near my house. A vehicle entered the highway in front of me, going realllly slow (not uncommon in a farming area), and I had to get hard into the brakes. The rear straps stretched enough to allow the front straps to unhook. When I released the brakes the car rolled backwards and the car's rear wheels fell off the trailer. Fortunately the car stopped there, instead of completely leaving me, crossing the double yellow and hitting a minivan head on (which is what went through my mind afterward).
    Now I use three real car straps (like this: http://www.mrproducts.com/index.php?...tchet%20Straps ) and one 3/8" chain. The chain has a lower UTS than the straps, but it won't stretch.
    FWIW
    Ty Till
    #16 ITS
    Rocky Mountain Division
    2007 RMDiv ITS champion
    May 2005
    Staying off the walls
    1,049
    I use four 3500# working, 10,000 capacity rachet straps from Northern http://www.northerntool.com/webapp/w...70_21895_21895 with the hooks and clasps on four D-rings in the floor. The front ones attach to the "radius rods" in each corner and the rears to the lower shock mounts. Never had anything get loose and the car is in the perfect spot everytime no matter where it is.
    Tom Sprecher
    Wauwatosa, WI, USA
    2,658
    ***State law (not sure about Federal DOT) here requires FOUR load securement points.***
    Good point, will look at state laws. I have thought about one chain front & one chain rear many times & said to myself, hmmmm. As I'm typing I remembered the time I was towing at black night to Blackhawk Farms, stoped by a state troper because the two chains from the trailer to the truck were sparking. He looked at the car tie down & said every thing else looked ok. Hmmmm I'll add an extra locked chain just to make sure if either of the others let go the car stays on the trailer. Thanks
    Have Fun ; )
    David Dewhurst
    Spec Miata #14
    Oct 2007
    Decatur, AL
    11
    So should the straps be crossed or not? Currently I'm not crossing the fronts only because it's easier for me.
    Sweet! The thread is EXACTLY two years old today! Great timing.
    Oct 2007
    Decatur, AL
    11
    Does that make a difference? Instead of starting a new thread I thought I'd post in an existing thread that was applicable.
    Wheaton, IL
    1,893
    It doesn't matter. Just a fun coincidence.
    I cross mine. I like having the straps on enough angle to resist side to side and front to back.
    The VWs have some nice slots/hooks in the unibody that are used for train/truck transport, and I just use those to tie down. Sort of tough to reach, but dead rock solid. I would imagine most cars have something like this designed into them.
    Chris Schaafsma
    Golf 2 HProd
  18. #18
    Apr 2004
    Saratoga Springs, NY, USA
    225
    The U-Haul trailers only secure the front tires and have a chain in the rear Has anyone been pulled over due to this set-up?
    Team Jagermeister
    '03, '04, '05, '06, '07, '08, '09, '10 - ITB NESCCA Enduro Champions
  19. #19
    Aug 2006
    384
    I don't cross my straps for the same reason as Jake mentioned.
    Similar discussion here a few weeks ago:
    http://www.roadraceautox.com/showthr...ghlight=straps
  20. #20
    Northeast
    7,031
    Textbook method: Cross the fronts and straight back on the rear.
    Crossed fronts give you the side to side you should have and straight rears give you the strength under braking or in a crash.
    New England Region 188967
