Results 1 to 20 of 22
Thread: Super Touring Rules
    Jul 2004
    Raleigh NC
    3,682
    Look at that table and you'll see that the precedent has been set for approval of 3L+ requests on a case-by-base basis, primarily based on expected engine output.
    We don't have a hard-and-fast output upper limit for STU, right now it's one of those "you know it when you see it" kinda things.
    Isn't this philosophy different from what many of us here, including yourself, have advocated over the years - set rules with a repeatable classing process? Either the engines are allowed by the rules or they aren't. Otherwise the class is open to various biases and might seem a little Prod-like (from what little I know of Prod).
    I'm just collecting all my options for where I might be able to run a pushrod 2V 3.8L six in the SCCA. If I want the car considered I should write a letter I suppose?
    Thanks,
    Ron
    It is. But in my defense remember I'm not a committee of one...and other members have made compelling arguments for such allowances.
    My primary beef with STx was an apparent lack of a clear philosophy, and thus no clear way for either the STAC or the competitors to make reasonable competition decisions. I was a big proponent of getting that done even before I joined the committee. Toward that end, a lot of good things have come out of the committee this year, we've had a lot of good long-term strategy discussions, and we are now polishing off a new philosophy that we will reveal via Fastrack shortly. It will replace the entire "A: Purpose" section and will define what the committee sees as the philosophy of the category as a whole, as well as the perceived philosophy of each class. This will be the basis for competition decisions going forward and in my mind each and every decision made by the committee will be weighed against this stated philosophy.
    As part of this philosophy, we will encompass some of the 3+L engines within a hard-and-fast engine size limit, yet also welcome the existing V6 pushrod engines on case-by-case approval (as is now).
    This will all get discussed next concall, so I'm hopeful to get our proposal to the CRB/BoD/membership in the next Fastrack. Be patient, I'm hoping you'll like what you see.
    Jul 2004
    Decatur , GA, USA
    183
    Greg - Just for clarification, if engines like Ron's are allowed, will they be given a weight based on HP/weight or on "power number"/ weight? In some of the earlier discussions, it appeared that "power number" [(HP + torque)/2] was to be used instead of HP. If it is power number, then a relatively low revving engine like the V6 Ford would seem to be at a serious disadvantage.
    Tom Lyttle
    Decatur, GA
    Tom, I can find that out for you. From memory, I think the pony-car pushrod 3.8s are currently classified at 3200#, about the same as a 2.9L "regular" STU engine...
    Jul 2004
    Raleigh NC
    3,682
    I'll be interesting how this will turn out. I'll be waiting to have a read.
    Quote Originally Posted by TomL View Post
    That is where I was going with the valve curtain question that I posted earlier. If we allow cams to XXX lift, that is all well and good, but if we don't consider valve area then two valve motors are going to operate at a distinct disadvantage. To make a stab at parity the two valve motors should have a higher maximum cam lift. It is a relatively easy calcluation to make and the class could be based on displacement/valve area with a good chance at parity because we're not limited to stock cam specs.
    Dec 2008
    1,391
    Ron - cams in STL get more lift AND less weight if they only push 1 valve per cycle (there are rules for 2/3/4+ valve setups). It's a blanket allowance, not based on the shape of the motor, just like TB, intake, and head design are all "equalized" in the rules (by which I mean ignored for effects on overall power potential).
    I think they could work something into the STU rules for 2V "equivalency", published or not (STAC: we'd all prefer to see it) that will take this into acount. Just like in IT, the best you can hope for is grouping, not bullseye.
