How do the FI engines and the carb engines differ? I know the carb engine brought air in through the fender well holes. How about the FI engine?
Same, essentially. A flexible tube ran from the AFM to a large square air box with the filter that was attached to the fender hole on the passenger side of the car. The driver's side, unlike the carb car, was not used.
The air box was very restrictive and apparently putting a cone filter simply in the area of the hole (engine side) was worth 5-10 hp.
I still think best place to take in air is under the grate at the base of the hood.
My Honda's are displeased that there's VW, Triumph, & Volvo talk in their forum. They're kind of elitist.
Kevin
2010 ITB ARRC Champion
2008 & 2009 ITA ARRC Champion
'90 FP Acura Integra RS
'92 ITA Acura Integra RS
'92 ITB Honda Civic DX
>> If there is space to allow a tube to run up to the grill without modifying anything I would think it would be legal as long as it wasn't mounted flush up to the grill. If it was mounted say 1" behind the grill it is essentially getting air that is from inside the engine compartment. Now if it was mounted directly to the grill then the air is from outside the engine compartment as it never really entered the engine compartment. What are your thoughts on this?
I personally don't think that's intorturtation. We do a conceptually similar thing on my Golf, having cut up the bottom (pre-filtered) side of the air box to allow it to pull air from the vicinity of the space behind/below the front bumper, on the outside toward the fender well.
One data point: We punched out (well, Greg A punched out) a right side headlight at the Summit 12 hours. I seem to recall that Cameron came away from that convinced, based on data on the DL1, that the ECU got smarter as it figured out that cool air was being packed into that space, and adapted to make more power.
KK
