the 2.0L is under the "normal" displacement, so would loose some there (100#). the other doesn't.
my mistake it's a tq/disp adjustment. to my knowledge, never applied other than the 5.o,5.7L etc... cars getting +150#.And how would the Vette gain weight seeing as it already has 150lbs 'extra' for torque? Does the ops manual have a double whammy for displacement AND torque?
disagree. the strut adder ONLY affects FWD cars. it's not a 100lbs split RWD strut to RWD DW, it's 50. it's 100# to the FWD guys, so I agree we should do away with it. I think following the standard +50 foe DW formula is easier, so vote that way.Again, a separation between struts and DW is needed IMHO. Just get rid of the double application of the adder. The Vette is taking it in the ass on that front.
no offense intended, but it's an easy to follow conversational reference to the process for which you are arguing, and which determined the bulk of existing ITR classifications. and believe me, I've kept up on the history. THANK YOU (and kk and jg and js etc..) fo getting us here. please don't be upset when we try to use the tool you worked so hard to leave us with.And PLEASE lets stop with the 'your' process stuff. I know you meant the 'collective' your...but I was the author of the deduction by % change. You see it in your ops manual now because of that regimes work. And frankly, that was one of the 'changes' that was on the pile when the CRB lost it's mind about the process.
the membership has access to the ops manual, and I think it's fair that they should be able to monday morning quarterback our work or a theoretical classification and get the same results we do. that's really the crux of the situation.
it is a DW car and it did get +50, like the vette, though AFTER a -6% that -6%+50# is still a 25 larger weight break than the "old process" (better?) would have given it (-100 for FWD only).EDIT: Why would the TSX ever get consideration for +50 for suspension? I would hope it's a strut car or else it would have gotten the +50 just like the Vette. No?
while we're on the subject, can anyone from the realignment era committee explain the 100# weight break to the S2000 as shown in the spreadsheet under the "other" column?
