Originally Posted by
Greg Amy
What Do You Think
ITR
1. #11955 (Lee Niffenegger) Move 2006-Up Civic SI from ITS to ITR
The Club Racing Board seeks your input on this question. Please submit responses to crbscca.com. Should the 2006-2008 Civic Si remain in ITS at 3000 lbs or be moved to ITR at 2605 lbs?
ITS
1. #11724 (Willie Phee) Classify Acura TSX in ITS
The Club Racing Board requests member feedback for this question. Please submit letters to crbscca.com. Should the 04-08 Acura TSX remain as currently classified in ITR at 2760 lbs or be moved to ITS at a weight of 3175 lbs?
I sent a letter to the ITAC/CRB (
http://crbscca.com/) pointing out that no matter what you do, you're gonna piss someone off, likely someone already running or building a car.
So let's stop dancing this silly little "where do you want this car to be?" tango and approve dual classifications in Improved Touring.
Done. - GA
When my "tweener" 99 Civic Si was classed, there was some back and forth between people wanting it in ITA at higher weight, because there were plenty of former SSC cars that could have run without a massive stripping-down effort. After initial claims the car could not make ITS weight, some builds claimed it could, so it was moved to ITS. The argument for that procedure was, as I was told, that "we want every car in the class where it has its lowest attainable weight."
I can see the merit of this approach, but it seems inconsistent with what they do now, ie ask people about their preferences. As Greg said, this approach will piss people off no matter which way it goes; with a consistent "lowest reasonably attainable weight" procedure, there'd be at least a consistent rule to point to that would prevent some of the bickering and arguing, and perpetual requests for reclassifications.
Yes, dual classifications would be the way to go IMO. No violation of the process, with the downside of request for power/weight assessments, special allowances, etc being submitted for the same car in 2 classes; I'd assume the increase of such letters would be rather mild though, since most cars are pretty firmly planted in one class.
EDIT: Dual classifications would also lower the entry barrier for new car builds, and mix up the competition. Beginner car and not worried yet about winning? Leave your fresh build at the heavier weight, leave the sound dampening and nasty underside coating on and the glass in and go racing. Car a bit of an underdog in one class? Maybe try the other; could increase diversity in the fields.
Astrophysathingy / goaheadtakethewheel.com
99 Civic SI #9 WDCR ITS/STL
93 Corolla / 97 PDX Miata
