And then the protester appeals to Topeka, where, apparently, cooler heads prevail*...
What makes you think you can? Do you really believe you write a rule that I can't intorturate?...why not try and LIMIT the potential for intorturtation?
If you think the rule leaves open a gray area for intorturation that someone will take advantage of but that Topeka won't support on appeal, then we've got the process to address that (i.e., protest, then appeal, then Fastrack publication). But, if you think Topeka is going to let it go as 'legal' then what you're proposing to do is not clarification but a de facto rule change (i.e., if Topeka says the intorturation is legal, then your clarification is actually a rule change that must go through the process.)
On the other hand, if the intorturation is accepted by the community as contrary to the spirit of the rules, and it gets protested, then appealed to Topeka, and Topeka says it's legal, then - and only then - should we proceed to request a rule change to make it illegal.
This is especially silly when one recognizes that it's NEVER been done (as far as we know) and that the only reason it's come up for discussion is because someone, in some forum, tossed it out as a theoretical possibility. Are we going to be tilting every Internet-based (or email-based, or paddock BS-session-based) theoretical windmill we see/hear, or are we going to use the protest/appeal process that's been in place for decades as it was intended?
The process works, dude. Don't f**k it up.
* A perfect example: the spherical suspension bearings bastardization. I was *this* close to having Topeka make a ruling on those, using the existing, GCR-defined process, when someone on the CRB decided to unilaterally and preemptively over-ride the GCR process. Had I been allowed to proceed, we could have used the process to change the rule, which most reasonable persons agree it was.
