As this survey was broadcast across multiple message boards, you've got a cross section from multiple sanctioning bodys, and of those only the SCCA doesn't mandate SFI/FIA compliant devices. That is if you run even once a season with NASA, BMWCCA-CR, PCA, or any number of other sanctioning bodies, if there isn't a SFI sticker then there's no racing on the track. I say this not because I'm a fan of HANS or the SFI spec, because the wording of the SFI spec requires a device that crosses patent lines. For an example look at what's happening to Defender being sued for patent infringement. What might the outcome of this suite be? Is there a chance that Downing/Hubbard might loose the rights to future patent income because the also wrote the SFI spec?
On a side note, did anyone see the glowing write up of D/H in Grassroots? Is anyone planning on writing a letter on that?
