wow. Dang thing got real
I too agree with Andy.
I think it is entirely unfair to say the ITAC wasn't doing a good job during that time period. We routinely spent 4-5 hours on the calls, talking into the wee hours of the night, to come up with the (at the time) ONLY objective, repeatable and written down system for classing cars in the SCCA. That was a sea change of epic proporitions.
There were miscommunications between the CRB and the ITAC, but I tihnk everyone -- Bob Dowie, Andy, everyone -- was trying hard to do the right thing. THe problem was that we were really doing something revolutionary, and the basis for it (stock horsepower) was causing the CRB a lot of heartburn (as it should).
But not doing a good job? No, that is simply wrong.
The ITAC has, or at least had, one of the toughtest jobs in the SCCA. We have the most popular multi marque class that actually is multi marque, and we had to come up with an objective process to set car weights that covered something like 300 chassis stretching from 1968 until 2008.
Drago said something I also posted some time ago--the RX8 doesn't seem an overdog, the Runoffs winning car was simply very well prepared and driven. My T4 RX8 has run times similar to decent STL cars like Walke's RX7, but is seconds behind top STL builds. Walke's car and an ITS Miata running STL were quite a bit faster than the RX8 down the Road America straights, I made up time in the corners (more tire). Admittedly my T4 RX8 is a bit heavier and less prepared than an STL version, but the straight line speeds will not be much different. If I took out the weight to run STL I would then reduce the tire so overall the car would not be much faster; under the current rules I would also have to run the plate which slows the car even more making it uncompetitive. The plate seems like an over-reaction to the Runoffs; do any of you on the CRB/STAC have an opinion on chances of removing the plate?
ST has taken that job over, considering ST allows engine swaps, turbo charged and supercharged cars and allows different levels of engine and drivetrain modifications.
Nedless to say, it's not easy, and the lack of strong full-build true ST cars running regularly against each other - and the resultant lack of head to head competition and onboard data - is not helping.
THAT said, can we move the ITAC issue from 5 years ago or whatever to a different thread and keep this one on ST "DEFINITION OF A TOURING CAR"
The BOP between the Miatas and Integra looked pretty good this weekend at the SARRC Championship race at Daytona. Equally prepped and driven. PK
