What year car do you have?
On the SN95 cars that bundle is about 1.5" thick and has at least 60+ wires. The majority of the wires are for the keyless entry system, the stereo (this car has the Mach 460 so many wires), cigar lighters, parking brake switch, cross harness that connects both door harnesses, the passive anti theft system, defroster, lights, backup, brake lights, fuel pump, fuel sender, immobilizer, and that is about it.
All I wanted was the brake lights, tail lights, fuel stuff, defroster, and signals. You might want less.
The harness is done now and I'll take pictures of it. Very slim and svelte with probably eight wires going to the back. Now the harness will cross and route under the dash instead of over the tunnel, another reason to clean it up as you can get rid of the mid-branches and get them out of the floor pan. Weight is coming out of the car. A few pounds at a time, but it is coming out and will add up.
The door skins were surprisingly light. I suspect you'll find the package tray is somewhat similar, maybe five to six pounds. If you have a Fox car there were some plastic bumpers you could use but I don't know where and what year models those were. The SN95 bumpers don't weigh much at all and even if I could toss them I probably wouldn't.
