Results 1 to 16 of 16
Thread: Suspension Airbags
    Sep 2005
    Earth
    743
    Had Timbrens on the E350.....hated 'em. Have airbags on the F250....love 'em!
    Ed Funk
    Trussville, Alabama, USA
    1,087
    Load equalizing hitch will raise back of truck to compensate for tongue weight and still give you a good ride.
    Chuck Baader
    White EP BMW M-Techniq
    Apr 2008
    St. Louis
    62
    Quote Originally Posted by chuck baader View Post
    I have a similar Ram and agree on the rear suspension. I went with the above and has worked well so far.
    May 2003
    Colchester, CT, USA
    2,120
    Just thought I would update. I did go to the Timbrens website and check it out. Yes, what was discussed above was basically a bigger bump stop. I had some e-mail back and forth from eTrailer tech. They recommended another Timbren product. I dont have the link at the moment but it is like a rubber puck that fits between the springs. It's supposed to improve handling as well as "some" additional load leveling capacity when towing. Tried them out on a three hour each way trip and I am very happy with them. I cant say if it helps handling (although I am going to get them for the front which I think will help the handling) but the bouncing when towing was MUCH better. I am very happy with the product and it was easy to install (15 minutes or so?) I like a very stiff ride in my trucks so I may throw some good shocks back there is well. I think it's a great solution for coil springs without going full air bag.
    Jeff L
    ITA Miata
    2010 NARRC Champion
    May 2003
    Colchester, CT, USA
    2,120
    Quote Originally Posted by Ed Funk View Post
    Ed, what didnt you like about the Timbrens?
    Jeff L
    ITA Miata
    2010 NARRC Champion
    Sep 2005
    Earth
    743
    On our van, we only had about an inch of suspension before contact with the Timbrens. At which point , with no load, the ride became VERY firm. I like the bags because you can easily adjust for load or no load. Do recommend some top of the line shocks like Bilsteins with the bags to handle the extra spring rate.
    Ed Funk
    Ed, that doesn't sound like they were installed correctly. The bags are supposed to be in contact at all times, and you adjust firmness via air pressure.
    Apr 2010
    Boston, MA
    145
    Interested in this too. Looks like the ride-rite system is a no-go, since that is for leaf suspension. This is a different setup that seems to be the solution:
    http://www.sdtrucksprings.com/firest...1500-2009-2014
    '77 Mazda RX-3
    NER SCCA E-Prod
    Sep 2005
    Earth
    743
    Read it again Greg. The Timbrens are like giant bump stops, and are non-adjustable. I like the airbags.
    Ed Funk
    Roger. No indications in your post(s) that "Timbrens" are bump stops, not airbags (as per conversation topic...damn doctors...)
    Sep 2005
    Earth
    743
    WHAT eva!
    Ed Funk
