Have you tried the dry ice on the sound mats?
Steve Eckerich
ITS 18 Speedsource RX7
ITR RX8 (under construction)
Makes for a cleaner interior. Put the ice in a big thick plastic bag and break it up with a dead blow hammer. Lets you get better contact with the surface. After you see frost on the underside hit the area with the dead blow softly to break it loose. It took 15 minutes to strip the entire RX8. If you have a lot of melt strips and liner to remove just go by the welding supply place and get a dewer of liquid nitrogen, it is really fast with that.
Steve Eckerich
A guy out in the NW built what he called the "death ray..."
http://www.rallyanarchy.com/phorum/read.php?5,6465,6493
Thanks for the tips fellows because I'll have to go after that weight. No death ray is available but 25 lbs of dry ice I can get on the way home from work.
We were able to scale the car up tonight and see where we're at. I have to say we're better off than I thought we were, but not where we need to be.
We're essentially at 2510 lbs with the stock tank and about 12 gallons of gas. So I'd feel comfortable calling it 2440 lbs. There are still things left to remove - cruise control, some airbag crash sensors, and a few other odds and ends like comparing a fuel cell to the stock tank. But there is a lot to put back in - cage, race seat, harness, fire system, and other racing related items.
So in addition to those dampening pads, which isn't going to be fun, I'm going to need to attack the wiring harness and remove optional circuits that we can legally remove. There are a lot of them - ABS, anti theft, power windows/mirrors/locks, AC, and so on. The harnesses are very heavy. Tonight we spent time separating the metal from from the dash so we could get to the dash harness - just the dash harness weighed in at 9.7 lbs and the door harnesses were a bit over 1.5 lbs each. In this respect it would have been nice to have obtained a five speed manual non-power window non-ABS non-AC car that never had all the options, but the single example of that I found, which took almost a year, was in very poor shape. Ford quit make the stripper cars in 95 so if you're inclined to find one look for 1994 and 1995 models, after that they all had quite a bit of options regardless of trim. Anyhow, I'll need to be thinking about very light rear suspension components as well as a light ($$$$) seat.
I have to say I'm encouraged. I know we'll never make the 24XX spec weight but if we could score a 2700 lbs weight with driver I feel we could make the car competitive. I don't think it'll ever be one of the "cars to have" in ITS but I think it can be a contender and add some flavor to the class.
..washer .....washer bottle....Must.....must not remove.....washer bottle......
Not a whole lot under the fenders to deal with. Cruise control, washer bottle, ABS stuff, and the controversial carbon canister, which in a race paddock is more rare than rocking horse poo.
One thing that is notably absent is rust and undercoating, a welcome change from the Z.
Forget the dry ice...sort of an urban legend and very much material dependent. For Fords you need to get the cold under the material and you therefore need to be on a rotisserie.
The N2 death ray is the nuts.
For me it was a acraper and a Dynazip. Hardwork but it gets the job done.
