Results 1 to 20 of 31
Thread: 240SX clutch
    Nov 2004
    Lilburn, GA
    597
    It's a stock PP and disc as far as I know. Bob said he just used stock and that's probably what I'll use as well. Only a couple hundred bucks from Courtesy. I'll get a new TO bearing as well. I can't recreate the issue in the garage so it's been a guessing game. If the spindle that the TO bearing slides on is damaged is that something that can be replaced? I have a spare transmission I could scavenge parts off of if necessary. I don't know the condition of the internals on the spare so I'm not sure I'd want to use the whole thing, but that would be an option.
    Thanks.
    Edit: Is this the part that would need to be replaced if the TO bearing spindle is worn?
    http://www.courtesyparts.com/32110-c...4-p-69353.html
    Looks like there's a sleeve that fits into the TO bearing that slides on the spindle from the front cover.
    http://www.courtesyparts.com/240sx-p...1487_1501.html
    Double edit: I'm just going to order everything from the PP/disc down through the front cover. If I'm going to replace one thing I might as well go ahead and replace it all.
    ITA 240SX #17
    Atlanta Region
    Sep 2002
    Fredericksburg, VA
    1,191
    As I recall, didn't you tell me that this has only happened on track, at speed? The more I think about that, the more I think it's probably a PP issue. Is this the same one that was in there when you bought the car from Bob?
    FWIW, my car had a stock type clutch when I started racing it, and it wasn't long before I started getting slippage about 15-20 mins into a race. While I know our cars don't make much more power than stock, we are still abusing them well beyond what the stock components were designed to handle. When I built the engine I replaced the clutch with an ACT heavy duty plate & 4-puck disc, and I've never had a bit of trouble since then - 5+ years and maybe 15-20 events later. YMMV
    Earl R.
    240SX
    ITA/ST5
    Trussville, Alabama, USA
    1,087
    SPEC clutch stage 4 with aluminum PP option...3 puck ceramic solid hub. About the lightest thing you can get. Chuck
    Chuck Baader
    White EP BMW M-Techniq
    hey guys i think a company FRsport or enjuku racing is offering some carbon "white bunny" clutch combos for ka engines. i believe they are thru competition clutch
    May 2008
    CT/NY/NJ
    1,157
    Mark wrecked at WGI in the laces at the Last Chance.
    Chris Rallo "the kid"
    Jan 2010
    Houston-ish
    932
    Quote Originally Posted by DavidM View Post
    Thanks.
    Yup, if you're going to replace the front cover, purchase 32110, 32113, and 32112. one each.
    you'll know what kind of shape it's in as soon as you pull the tranny out of the car. They're not that expensive and they don't wear out often, but you never know. I've seen one or two wear out in probably 30 clutch jobs on various cars. both failures were on nissans with >150k miles.
    I would not recommend an OEM pressure plate (or clutch disc) for a race car. they just don't hold up well enough in the long run. I've used ACT products for years and have been happy with them- pick any brand you choose, but do your tranny a favor and keep a sprung hub configuration. the solid hubs are lighter and rev a tiny bit quicker, but transfer much more shock load to the crank and to the tranny. this beats up on the baulk rings, which are a known weak link in the KA tranny.
    (FYI, I've been through 2 trannies in the last 3 dbl nat'l weekends. eek!) one was just plain worn out, the other I missed 4th and tried to find 6th at 85mph. there went reverse!
    Houston Region
    STU Nissan 240SX
    EProd RX7
    1,087
    David, see that you entered the ARRC...what did you do for the clutch? Chuck
    Chuck Baader
    Nov 2004
    Lilburn, GA
    597
    Haven't done anything yet. Got all the parts coming to replace things this weekend. I ordered everything from the front cover through to the clutch disc. I'm going to stick with the stock disc and PP for now. At the rate I'm going with racing they'll last me a long time. I haven't raced since last year's ARRC. I'm going to do the ProIT to try and shake the cobwebs off before the ARRC race, but I'm still going to be slow.
    ITA 240SX #17
    Atlanta Region
    Nov 2004
    Lilburn, GA
    597
    Alrighty. I've got the transmission out. I see nothing that's immediately evident as the cause of my problem. The release bearing sleeve was fine and the pressure plate looks ok to me as well. The front cover appeared to be leaking so hopefully replacing it will stop the leak anyways. I've also put in a new release bearing/sleeve, clutch fork, and the little springs that hold it all together.
    Now for the really fun news. The disc and PP are not even remotely stock. The disc is a 6-puck and unsprung. The PP is similar to stock, but the springs look a little beefier. There are no markings on either so I have no idea what's the manufacturer. I've attached a couple pictures. The first is comparing the stock parts to what I pulled off the car. The second is a closeup of the disc. I went back and checked my notes from when I bought the car from Bob and sure enough he said stock disc and PP. He even said stay away from Centerforce. So now I'm not sure what to do. I sure don't want to put the stock parts on and then have to pull everything apart again because it doesn't hold up. I've always heard good things about ACT and that seems to be what you guys are using. What came off the car was a 6-puck so I'd lean that way vs a 4-puck. The disc that came off was unsprung, but maybe that's not the way to go.
    Any thoughts?
    Edit: ACT has the heavy duty PP and a sprung and unspring 6-puck disc. I see how using the sprung would reduce vibrations, but the springs seem like they could be a failure point. I've had the unsprung in the car and the tranny doesn't seem any worse for wear, but maybe symptoms just haven't shown up yet. Earl, is your disc sprung or unsprung?
    Attached Images Attached Images
    ITA 240SX #17
    Atlanta Region
    Jan 2010
    Houston-ish
    932
    Sprung hubs will make the tranny last longer as it reduces drivetrain shock during shifts and on/off throttle transitions. they add a tiny amount of rotating mass, but help to save your synchros and baulk rings.
    Houston Region
    STU Nissan 240SX
    EProd RX7
    1,087
    The six puck is gross overkill. A three puck will work fine and be much lighter. You might see about having the original pp rebuilt and return the stock parts. I would do that before installing stock parts. (BTW, I run a 4 puck solid ceramic on a 250k plus transmission) If you have the original pp rebuilt, it can be checked for problems that may have been causing the clutch problem. Chuck
    Chuck Baader
    Sep 2002
    Fredericksburg, VA
    1,191
    Mine is the solid 4-puck disc. It's a little rough to drive around the paddock, but once on track you can't tell the difference between it and a stock clutch - except for the no slipping part. The trans is a 100k+ mile one I replaced in '06 (before the new clutch), and it's still working fine. I wouldn't hesitate to put the same clutch back in next time.
    Earl R.
    240SX
    ITA/ST5
    May 2008
    CT/NY/NJ
    1,157
    Plus one for don't use Centerforce! One failed in our 240sx.
