Not frankensteins, just a part from here and a part from there that happen to be the same in every way as the part you need for the specified engine. you can't take a B16A3 head and a B18B3 intake and call it compliant to anything. they never came in that config. but to my knowledge, the B18C/B17/B16 are all the same blocks. the ASSEMBLY is stamped as whatever it was, but that doesn't make the shared parts unique.
yeah, you might have some 'splainin to do if you call your car a 1600 and there's the block from an 1800 in there, but measure the stroke and come out B16 spec and you're fine, IMHO.
the mazda turbo thing was pretty sneaky - the alternate MSP part was allowed as an alternate replacement for the MSM and not well vetted by the rulemakers when approved. but it was SPECIFICALLY approved, then rescinded. alternate parts that match OEM are allowed by the category rules and do not need a line item, nor does using them open a box labeled "Pandora, keep closed."
legality is an enforcement via measurement and material issue, not a stamping one.
happy 4th thursday in November to my Can"eh"dian friends.
