Actually, the 325e is in ITA.
You need to find Chuck Baader, who built and races one in the SEDiv. Great guy, and his car is way fast. He posts here, just can't remember his handle.....
Jff, Thanks I guss I missd th E!
R
Rob Breault
BMW 328is #36
2008 NARRC DP Champion
2009 NARRC ITR Champion
2009 Team DI Pro-ITR Champion
x2
Chuck's the guy I'd suggest too. Not sure how much he's on here but you may want to cross post your questions over on www.roadraceautox.com too. I think his username is CWBaader over there.
Christian
Thanks all. I am a 50 year old newb, so I don't figure on needing all that much car to begin with, as I say I am just planning on safety and dependability until I feel I am as fast as the car. The main thing I am looking for are little areas that need attention on these cars during to construction, just trying to save myself some extra headaches if possible.
The car is an 84 e30, by the way, and thanks again.
Chcuk's older than you! LOL..sorry Chuck, had to get a dig in, specially since you routinely beat me at Roebling......
Get a hold of Chuck, he has the car pretty well figured out and can help you a lot. I happen to think the 325e is one of the very best choices in ITA right now. NOTHING in A makes anywhere near the torque your car will make.
Gibson, yes, Jeff is right...I'll be 65 this year
Answers: Thermostat...drill a 3/16" hole in the stock thermostat where the arrow is and forget about it. With the cooling system design, you must run the thermostat.
Diff...bulletproof. Use Amsoil diff fluid, 80W120 (I think) without additive. 3.73 gear.
Use a crank scraper.
I made a 8 qt oil pan with extreme baffling to combat oiling problems (specifically in 3 at RR). Have not tried an accusump but I did not care for the restriction of the one way valve. Just my opinion.
You should be able to adjust camber to -4 degrees front and rear.
I have plans to be at RA March 13-15 if you want to see the car.
Hope this helps, Chuck
Chuck Baader
White EP BMW M-Techniq
Thanks all for your help.
I will definitely try to come by Road Atlanta that weekend, I don't need much of an excuse at all to hang out in the pits of a race track.
Thanks again.
After talking with Mr. Badder, search Bimmerworld, then track Matt Reppert down....his ITS car handles really well from what I've seen.
david
30 year old ITS car
