I must admit i am uncomfortable with the intake breaking the plane of radiator.
dick patullo
ner scca IT7 Rx7
Fair enough. So look at that photo of the item installed again. Note that the piece that extends well past forward of the radiator is the mounting system, and there's no limits to the mounting system for the air intake, only limits to where the air is sourced. If he were to trim back the top of that item, where the initial opening of the air source is, to a point right at the vertical plane of the aft edge of the radiator, would that not satisfy the letter (and potentially the intent) of the reg?
<johnbishop> It's illegal. Period. </johnbishop>
Kirk (who freely admits that combining obtuse references to both html and '70s-era IMSA is probably leaving pretty much everyone out of the joke)
I have no problem with it. Unless you are going to mandate bone stock air filters and housings, it works.
I think I may have accidentally discovered where the item is moot, regardless of compliance.
Look again at that photo of the stock 1.8L Miata. Note that there's a plastic cover over the area on top of the nose, in front of the radiator. This Jackson Racing part pulls air from that area when that cover is removed, and I cannot think of any way where removing that panel is compliant to the regs. Therefore, even if that intake is compliant, I don't think it's nearly as effective unless another non-compliant mod is also done, negating the whole point.
The 1.6L Miata seems to be open there, so may be useful for that car.
Agree/disagree?
Wouldn't that air intake be considered ram air and therefore not be allowed? "Velocity stacks, ram air or cowl induction are not permitted unless fitted as original equipment."
Ralf
ITB Golf GT
