As Matt noted, it's actually very easy to create a "calibration sheet" for an air impact gun. For example, I know that my Ingersoll 1/2" gun will, at 80psi on the regulator and using a 50' length of 1/2" hose, reliably hit 75 ft. lbs. Need a little more or less...just fiddle with pressure a bit.
That said, we ALWAYS follow up with a torque wrench. You're nuts if you don't.
