Results 1 to 20 of 22
Thread: Steering Column
    Asheville, NC US
    1,626
    Have to disagree with Greg here. Steering shafts are not tempered really, they are case hardened for wear and the inner 95% is soft. RB 44-48 on a Mazda. A proper filler rod with a tig on the large diameter of the shaft is just as strong as any adapter. Control the heat and do not weld to the small threaded area. But then I might be ignorant as well.:026:
    PS. If you have to ask on this forum how to weld it please take it to a professional so you don't end up holding a wheel with no car attached.
    Steve Eckerich
    ITS 18 Speedsource RX7
    ITR RX8 (under construction)
    Quote Originally Posted by seckerich View Post
    Nah, I'll defer to you on that, as I'm only half-sure on the process. However, I am sure they're heat-treated in some way and that improper welding can affect that, and I am very confident that welding on parts to them is neither a good idea nor compliant to the rules (as I described above and in those other linked threads.)
    But, it's not one of those "areas" that's worth getting all riled up about (unless you're a stickler for rules as we tend to be...) - GA
