You're correct sir; this is what they have on Hoosier's website now (which I'm guessing you've already seen):
Along with this chart:Traditionally, Hoosier tires have often required higher pressures than other brands. This has changed with the A6/R6.
VEHICLE SIZE RECOMMENDED HOT PRESSURE COLD PRESSURE
1800-2200 LBS. ..........................30-33+ ..............22-27
2200-2600 LBS. ..........................31-34+ ..............23-28
2600-3000 LBS. ..........................33-37+ ..............23-28
OVER 3000 LBS. .........................34-39+ ..............23-29
