If you are talking about the "right side net," we've got one in my Golf.
Talking with some folks I trust, the argument is that - particularly with the halo seat - if the driver stretches out in an impact, the net guides his/her noggin back INSIDE rather than OUTSIDE of the head restraints. We worked hard to get the angle correct (it seemed easy to mount it higher than it should be if one just guessed), and to make the mounting stout enough for the net to pull tight. They actually have a ratchet tensioner. We used a seatbelt mounting eye in the firewall, behind the dash.
EDIT - it's not clear in the pic but the net is TIGHT against the seat halo.
