Hello,
My school for Blackhawk Farms is a couple weeks away and was wondering what the alignment settings should be for a '84 Scirocco (equipped w/ camber plates, coilovers, Bilsteins, unknown springs with half used up Hoosier R6's).
The PO indicated:
Front toe out .06 at the wheel
Max front camber
front caster 2.5 deg. Verify tire temperatures
Rear alignment should be set by shims. 0 toe, 1.8deg camber check tire temps
Are these correct or any other suggestions?
TIA,
