Results 1 to 5 of 5
Thread: Gen 2 Vert
Threaded View
  1. #3
    Aug 2005
    1,717
    Last time I read the GCR's only vert cars allowed in IT are cars specifically designed to be a vert. Since Rx-7's are coupes originally, then the vert's not classed in IT.
    edit....
    here it is, 9.3.1.8.f
    f. Convertible tops and attaching hardware shall be completely
    removed. Note: Convertible model cars are permitted if they
    were only available as convertibles (e.g. MG Midget), or if the
    convertible model is specifically allowed on the vehicle spec line.
    Convertible models may compete with their respective OEM
    hardtop. All latches shall be replaced with positive fasteners.
    Manual and electric sunroofs, original or aftermarket, where
    the panel is not normally removable shall be retained and run
    in the closed position. Components (motors, cables, rails) may
    be removed provided the panel is securely retained. Removable
    sunroof or T-top may be retained if bolted or welded in,
    or removed completely. Glass sunroofs must be removed. All
    sunroofs may be replaced with panel or replacement skin of
    the same material as the original surrounding roof material.
    STU BMW Z3 2.5liter
