if i wanted to pursue an updated ignition system for my ITB car (not sure at all possible yet...), can i have the newer larger igniter in a different location that would be outside the distributor?
the first gen crx ITB distributor is as follows and 11 is the igniter:
the newer crx's are as follows with 20 being the igniter:
and the GCR that i am looking at is
Quote:
e. Any ignition system which utilizes the original distributor for spark timing and distribution is permitted. Internal distributor components and distributor cap may be substituted.
Quote:
Ignition System - A system which converts on-board storage battery supply
voltage into a timed sequence of high voltage pulses suitable for igniting
engine combustion mixtures in a controlled manner.
so i see the igniter as part of the ignition system and not part of the distribution system even though it is installed with the distributor.
any thoughts?
