I noticed in 2005 the 1984-87 CRX-Si (injected) is in ITA at 1980#.
It is now in ITB at 2130#.
How do you legally (practically) add 150# ?
Re-install everything that was stripped in "05?
BTW, I have a carb'ed ITC at 1955#
Thanks,
Todd
Thanks,
Todd
As you noted, this is the 3rd season the car will be in ITB. The easiest items to look at first....
Once you do that stuff you probably won't have to do too much left
- Start your race with a full tank of gas.
- Put a spare tire back in (Hint: use a full-sized steel 14" or 15", not a space-saver)
- Re-install an original passenger seat
- Install ballast in the approved areas
Gregg Ginsberg
'96 Civic EX -- MARRS ITA #72
MARRS ITA/T3 Drivers rep
No, Kirk. This presumes that ITCS 9.1.3.D.7.a is valid.
There is no distinction currently placed on the spare wheel/tire vs. the other four and there are no limitations placed on the spare in that section. You do, of course, have the option of removing that spare (ITCS 9.1.3.D.10.c).Any wheel/tire may be used within the following limitations.....
Gregg Ginsberg
I'm not a steward but that's too much stretch.
The spare wheel and tire are treated in a separate section, distinct from the other wheels and tires - different rules apply. The spare may be removed but there's no allowance for replacing it.
Taken to the logical extreme applied by your rationale (to use the heaviest possible wheel for ballast in the rear), you're telling us that it would be OK to turn a custom spare wheel out of lead to poke over the rear axle, under the "any wheel/tire may be used" clause? If you're arguing that he should use a heavy stock wheel, under that allowance, why stop there and not use an "aftermarket" version?
Clever but not legal. <-- An opinion
EDIT - and there's no obligation for the rules to place a restriction on things we don't want people to do. If the rules don't specifically allow it, it isn't allowed.
I thought in previous GCRs is had a line which stated that only the original OEM spare tire was allowed? The wording always seemed clear to me that I could only use the space saver spare and not a full size.
Dave Gran
i am with K on this for the spacesaver spare tire. mine just took a couple #'s of wheel weights to get the balance just right.......
i have door bars, added a bar above the dash to the A-pillar front bars. will likely add a couple more bars. i had long since got rid of the passenger seat. and lots of stuff that you can add back in are relatively high (stock seat belts, etc.)
then i bolted ~120 #'s in front of the seat mounts. i welded in some angle iron to help locate the 50# blocks of steel.
i borrowed lead for a while but it would loosen due to the lead being soft.
>> ...mine just took a couple #'s of wheel weights to get the balance just right.......
Okaaaay.
Alternating between McDonald's, Wendy's and Burger King for 6 months should do the trick.
Jeff Roussel
Soon to be ITS Datsun 260z
Jeff's solution is the best...let nature take its course.
If you don't have time for a Supersize Me routine, try a nice, heavy gauge stainlees steel Exhaust system. The spare tire idea is common. Add an Accusump and associated hoses--you can pick where.
Cool suit cooler filled with water...bracketry to mount, etc.
Don't forget, there is no restriction on the size of the video camera.
Rodney Williamson
www.titaniummotorsports.com
