I am not sure how many different ways to say this...but just because everyone goes through the process doesn't mean they are treated the EXACT same way. Since we use PUBLISHED stock HP numbers as the base, and then derive another crank hp number as the target hp based on gains in IT trim, we have to be careful with BOTH numbers. The stock numbers can be low or high and the gains in IT trim can be low or high.
There are PLENTY of cars in the ITCS that are not classed on 25%. They are classed at known increases based on PILES of data. Trending if you will. Not lows, not highs, but documentable averages. Some Hondas, some BMWs, some Nissans some Datsuns, some Mazdas...some of these cars make significantly more than 25% and those numbers are used in the process. Some make less and they are used. Again, piles of data - averaged out.
Maybe you think the CRX went through the process and an arbatrary number was added - it wasn't. Known crank numbers were used INSIDE the process and sent on through. Nothing out of thin air.
Yes, I am fully aware you don't agree with this philosophy. But I think you HAVE TO do it like this (use what you KNOW) or else you get a class of overdogs. The BMW runs roughshot over ITS, the CRX runs roughshot over ITA, etc. So instead of letting it happen, and ruining a class for 2-3 years and then invoking a PCA, the 'proper' classification is done PROCATIVELY to make an effort to try and keep the road level.
A comp adjustment? Only if you are mistaken in your thinking that the 'process' is a formula. It's not. I would LOVE to have a formula - but nobody has shown me one I couldn't blow up. I hope the day comes when we can develop one.
