1990 ITA Crx with 500F and 700R eibachs,koni adjustables. Car is oversteering a bit. I know this NOT a usual problem with front wheel drive, hence the reason I need help. I have tried shock setting, tire pressure and camber settings. I have stock front/rear sway bars, 15x7 205/50-15 V710's all around. Car is 2250 lbs. Should I maybe go up 100lbs. with front springs or go 100lbs. down in rear? Any help is appreciated.....Thank you ........Jeremy
