The car is an 83 Rabbit so it will be run in ITB.
I just want to confirm the engine specifics before I start actually rebuilding the motor.
Am I correct in saying that I basically have one option and that is a Solid Lifter JH?
Does anyone have the correct part number of the block and head I should be running, as I cannot seem to find anything relating to that in the Bentley.
Since I am starting from the ground up I want to make sure everything matches to avoid any possible troubles down the road of part numbers not matching.
Also I was reading some old posts and someone mentioned that a certain JH head was better than others due to having shorter air-shrouded injector inserts. Anyone know anything about this?
Thanks alot guys.
