Results 1 to 3 of 3
Thread: underdrive pulleys for 84-87 Civic
    Sep 2005
    Earth
    743
    Does anyone have a source for them? Unorthodox lists for 88 and newer, and so far hasn't returned my calls or e-mails. Or will pulleys for later models fit?
    Thanks!!
    Ed
    Ed Funk
    Mar 2006
    31
    Contact Martin Burk . I believe he has a few in stock . His name here is TurnOnePROformance I believe.
    Roger Troxell
    Feb 2003
    1,106
    go back to the unorthodox website and click on the "BLEMS & OLD STOCK" "View all Listings" button.
    you should see that they have 8 total underpulleys of assorted colors of "old stock" for $40 each.
    these are the ones with two pulleys (alternator and A/C) of the Crank Pulleys - Underdrive Standard Belt Layout (Ultra S)
    if you want the single pulley that bad, turn it with a lathe.
    btw, the one i got may have been a Blem but the TDC and Timing marks did not match the stock pulley the best. i just scribed on the plastic cover per where my stock pulleys marks would be.
    these were pretty good deals as i was seeing used for the same price.
