After changing my torsion bars out the hard way once I asked an old 924 racer from back in the day. Now I can pull mine out of the car and juggle them and put them back in under 30 min. Thats a lie ,I cant juggle. The D production cars had camber boxes on the the torsion bar carrier to afford more neg camber on the rear wheels. Cant do this in IT but properly made eccentric bushings on the trailing arms on the torsion bar carrier will give you 4 degrees of neg camber. You wont need that much. On my production car I could change the torision bars for ride height faster than doing it with the eccentric bolts.The suspension arrangement in the rear of a 944 is adjustable for ride height, camber, and toe. It does take some experience and a few tricks to get them all right at the same time, but once you've done it a few times, it's really no problem.
It IS a total pain to swap them out - you have to remove the entire rear suspension from the car, so in that way, they are a pain. Fortunately, we don't do that too often!
Cheers,
Lawrence
