Who & what date was the best SCCA qualifying lap time for a 1st gen RX-7 in ITA/7 trim set at Mid Ohio ?
Who, what date & what model car has the best SCCA qualifying lap time for an ITA car set at Mid Ohio ?
Thanks
David Dewhurst
SCCA # 250772
Thanks
David Dewhurst
SCCA # 250772
The track record for ITA at Mid Ohio is held by Joey Moser in a CRX Si. The time was set 7-31-05 and is a 1:43.338. That was of course set during a race, but no has run faster than that in qualifying either.
The IT7 track record for Mid Ohio was set by Jason Albright on 9-11-05 at a 1.48.171. I don't know if anyone has beaten that in qualifying before.
Kevin
2010 ITB ARRC Champion
2008 & 2009 ITA ARRC Champion
'90 FP Acura Integra RS
'92 ITA Acura Integra RS
'92 ITB Honda Civic DX
I'd have to look at past results (2004 I think, maybe 2003) but I thought RX7s used to run into the high 47s at Mid-Ohio.
I'd assume they could run in the 46s now with new tires.
#69 ITA Honda CRX
I noticed just this past weekend that there wasn't any IT-7. Or at least none of them are running it anymore after the new weight changes. But either way, Jason was there last weekend (in ITA) and I'm pretty sure he was running at least 1:47's. I'd have to see the results again to know for sure, but in the CenDiv, it'll take at least a month for results to be posted up somewhere on the internet, if at all. Apparently uploading to mylaps.com is just too hard.I'd have to look at past results (2004 I think, maybe 2003) but I thought RX7s used to run into the high 47s at Mid-Ohio.
Kevin
***Apparently uploading to mylaps.com is just too hard.***
What he said ^.
Guys, the reason I am asking about the times is that Larry Dent of the Production AC stated that his boss had turned 46's at Mid Ohio in a 1st gen ITA/7. I don't nave a clue who his boss is. I had known of THE GREEN 1st gen RX-7 ITA/7 turning the 46 a couple years ago. One of the reasons (to fast with a non-ported motor) the 1st gen was turned down for G Production.
Thanks
Not germane to the topic, but interesting none the less.
While searching for an answer to your question I discovered that the 250cc superkart record there is a 1:26.026 and the 125cc sit up kart record is a 1:34.238.
Is that the same one that ran low 31s at Grattan?I had known of THE GREEN 1st gen RX-7 ITA/7 turning the 46 a couple years ago. [/b]
His engine appeared to be "very strong."
#69 ITA Honda CRX
***Is that the same one that ran low 31s at Grattan?***
***While searching for an answer to your question I discovered that the 250cc superkart record there is a 1:26.026 and the 125cc sit up kart record is a 1:34.238.***
Daryl what times do the Indy cars get around the joint in ?
Have Fun ; )
David Dewhurst
CenDiv Milwaukee Region
Spec Miata #14
I upload everything I get to Mylaps when I get it. Everything is usually posted through Neohio. If I can't get the AMB file from the local chief I can't post it. Waiting for MidO now. Sorry but can't figure out how to be in 2 places at once. IRP, Gingerman, Grattan and Nelson are all posted to Mylaps in about 2 days of the event, gotta have time to get home, dial up is not an option for this. Contact the local RE and tell them that you want Mylaps. The results are sent to SCCA in electronic files within 7 days of the event. Then we wait for them to be posted on the discussion. Can't speak for Area 5.I noticed just this past weekend that there wasn't any IT-7. Or at least none of them are running it anymore after the new weight changes. But either way, Jason was there last weekend (in ITA) and I'm pretty sure he was running at least 1:47's. I'd have to see the results again to know for sure, but in the CenDiv, it'll take at least a month for results to be posted up somewhere on the internet, if at all. Apparently uploading to mylaps.com is just too hard.
Shimoda, LMP1 Zytek 04S: 1:11.3
Jon Field, Lola: 1:14.6
Gavin, Corvette: 1:18.3
Bernhard, 911 RSR: 1:22.6
Daniels, MX5: 1:40.3
Auberlen, GAC M3: 1:34.8
Holtom, Cobalt SS, 1:38.2
Indy cars?
I'm not sure who's trying to compare what, but remember that there are (at least) two track configurations - with and without the chicane. All the regionals I've been to use the chicane - the Runoffs do not. Don't know about any other events.
Marty Doane
ITS RX-7 #13 (sold)
2016 Winnebago Journey (home)
Lap record is a 1:05.347Daryl what times do the Indy cars get around the joint in ?
Larry Dent. Prod advisory commitee? Have the members changed?
Tim
Tim his name was was within the info Scott Peterson posted on the Prod site with reference to the sorry assed reasons why the 1st gen was rejected for G Prod.
